I know its a tricky one but could anyone shed some light on this issue I've been having? Car is of course my little red coupe, it has a 1993 JDM GT EJ20G motor.
At idle it sounds real normal. I replaced the IAC valve again today (had the code again) and tested it, its running good. Freely revving it up it sounds ready to go.
The problem occurs when I load it up. As I take off it still sounds ok, but the instant I give it any sort of throttle it stutters and misses.
I am running the HEC716 coils and I have not yet installed the big injectors. This is the exact problem I had with the car before my recent re-conversion and I thought all the little problems I fixed would make it go away.
My biggest suspects are the coils, the injectors or the fuel pressure reg. At the moment there is no fault codes.
Any ideas at all?
