WAIC's are Awesome!!!
Post by D3V1L » Wed Mar 26, 2008 3:56 pm
shit matt ur engine bay just gets messier and messier:P
Post by Subafury » Wed Mar 26, 2008 6:57 pm
meh i dont mind if its messy- as long as it all works haha. it'll get a cleanup tho. i didnt think about the pump going dry but i did test it with the out let hose off and it chugs out plenty of water so it should be ok.
if i hadnt of rotated my compressor housing on the turbo i would of done what you did with the rs bov but now i have to work with this setup. its proving a little tricky to get this bov on. i also have an air hose that comes from the back of the thermo stat that was in my intake piping before, and also a sensor. car seems to run fine without them but i should prolly put them in.
Post by Gannon » Wed Mar 26, 2008 7:04 pm
The pipe to the top of the thermostat is for the Aux Air valve, fast idle on cold startup thingy. Dunno what sensor though.
I thought you had a TD04, which normally has its compressor outlet facing right and will work (pipewise) the same as mine allowing you to fit the RS BOV
Post by Subafury » Wed Mar 26, 2008 8:50 pm
Suparoo wrote:The pipe to the top of the thermostat is for the Aux Air valve, fast idle on cold startup thingy. Dunno what sensor though.
ah ok ill have to hook that random hose back on.
the td04 did fit like yours until i rotated the compressor housing- that way it would work with my existing intercooler setup. its a bit of a bitch to do so i wont change it back. its ok tho that side of the hoses fits good
Post by Gannon » Sun Apr 13, 2008 1:29 pm
Subafury wrote:relocate it in the fender like many people says fits awesome. well it doesnt for me.
I had the same problem, i tried to fit it in there, but where i could make it fit physically, the piping didnt work out, so i gave up and mounted it in the engine bay.
Xtreme_RX
Post by Xtreme_RX » Mon Apr 14, 2008 7:33 am
When i pull my guards off to do the motor swap I will post some pics of it....
http://www.subiparts.com.au
0438 887 746
Post by AndrewT » Mon Apr 14, 2008 6:18 pm
I'll have to try and get some pics of my wagon's mounting too. It seems to work alright in there for me too. Doesn't really matter tho, solong as it works :)
Post by Gannon » Mon Apr 14, 2008 6:34 pm
Xtreme_RX wrote:When i pull my guards off
If i had have pulled off my passenger guard, it would have made 'in guard' mounting easier, but i didnt think it was worth the hassle, especially if i have to take it out again if the bearings need replacing
Post by Subafury » Mon Apr 14, 2008 8:58 pm
ive heard the bearings inside are cheap and easy to replace?
