This current installation will not need the ECU I AM THINKING. For those of you with experience of ECU duties especially the three plug L series can you see anything the ECU does that will not work if it is all unplugged ? I am staring at some electrical diagrams
I can see the idle up for AC on will not work if it is disconnected, and the overboost? and some other controls clutch switch
I am hoping the ECU does not intervene in the general functions of the car other than fuel requirements. If necessary I can just disconnect the injector plug and maybe smash the ECU alert bulb
The whole method is to run the baby in a Brumby without an ECU but retain the separate knock control box and throw much of two L series out
ta
