Speaker rattle
Speaker rattle
I am getting a savage rattle from my mirrors in the Brumby from the stereo Just wondering how others have tried fixing it The doors are deadned and ported can you get poer mirrors to suit whats the go Ive got 6'1/2s in there and ill show my secret when I get home!
Turn down the volume?
Maybe add some rubber washers to the mirror mounts
Perhaps the adjustment set up behind the mirror is worn... or your door is internally rusted along the top inside where the support brace is for the mirrors. Or it's like my Hatch and the doors are imported so this support beam is actually missing... meaning you can't do stuff all else but get an Aussie spec door for it.
Is it doing it both sides? You do realise that if your stereo is up very loud there is no actual way to fix it... it's called reverberation.
Dave
Dave
Dave
Dave
bahahaha the idea is not to break the window stuff in the first placve:)
dave
dave
it is dynamat and it works awesome
Isn't it better to have somewhere for air flow otherwise it would start distorting the outer skin and start to make it reverb and unfortunately its not the aerial as its no longer in the factory position and I might check the inner door brace too because its only the right side that does it and you never know.
This was a little tricky to find at first because when I turned it up the shed used to rattle too!
For those wondering how to get good sound in your brumby even a wagon and the map pocket finishes just at the back of the seat so you can still reach things plus you can reach the seat controls on the side as for the interior light its been butchered too but thats another chapter But that headlight rattle would annoy the absolute hell out of me
- Brumby door2.jpg (27.05 KiB) Viewed 5002 times
