Brumby headlights upgrade
ChPLAT
Post by ChPLAT » Sat Feb 23, 2008 6:50 pm
My brumby has the square headlights so if I found driving lights the same size and made brackets etc. could I put them in place of the standard ones? I would probably have to leave the high beams alone I assume. But I have some old spotties already and don't really want to add driving lights elsewhere as its full. Anyways, legalities, pitfalls? any advice would be great.
-chris
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Feb 23, 2008 9:41 pm
You can get alot more from your lighting in the Brumby by adding some relays to give a proper voltage at the light increasing its brightness.
The long road ahead
ChPLAT
Post by ChPLAT » Sat Feb 23, 2008 10:12 pm
So relay it direct from the battery with a 30amp fuse inline? Would it do much for the old sealed lights?
Past rides-
1989 Brumby
Current ride-
brumbyrunner
Post by brumbyrunner » Sat Feb 23, 2008 10:12 pm
ChPLAT wrote:My brumby has the square headlights so if I found driving lights the same size and made brackets etc. could I put them in place of the standard ones?
You wont have to use driving lights or make up brackets.
Just replace the sealed beams with new inserts and Quatz Halogen bulbs. You can do just the high beam inners or all 4. As SWK said, first make sure you're got full power to the lights or you're wasting your money.
Settlement Creek Racing
Jack
Post by Jack » Sat Feb 23, 2008 11:37 pm
I had my Brumby's sealed beam headlights replaced with IPF inserts, IPF loom and halogen bulbs. Bought everything from the local ARB shop.
Wasn't cheap, but the headlight's performance is great now - both low and high beams. The upgrade worked so well, I haven't bothered fitting driving lights.
1999 Outback (some mods)
1989 Brumby (more mods)
Subaru - Symmetrical All-Wheel Drive
