wtf gearbox oil disappearing???
Post by Alex » Fri Feb 15, 2008 7:13 pm
hi all,
stupid question?
just took the wagon around the block to fill her up after 4 days of not moving.
The gearbox felt abit notchy into gears, so i checked the oil, NOTHING even registering on the dipstick. This box got new oil about 3months ago, and was filled till registering full at the time.
Where does the oil go??? There are NO visible leaks. (and its not like a gearbox can burn/use oil? can it?)
other members have had this problem as well
Post by AndrewT » Fri Feb 15, 2008 7:27 pm
Perhaps it registered full when you filled it....but then afterwards all the oil got dispersed throughout the gearbox. Not all the oil sits in the little sump to register on the dipstick.
This is possible if the gearbox was drained completely and left for a few years completely dry before you got it.
Have you checked the level since the first time you filled it up?
Post by Alex » Fri Feb 15, 2008 7:36 pm
yes have checked it numerous times since. Have noticed it slowly going down.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Feb 15, 2008 7:38 pm
Unless you can see where the oil is leaking from i would have to agree with the above comment.
The long road ahead
SuBaRiNo
Post by SuBaRiNo » Fri Feb 15, 2008 8:27 pm
Could it be possible it has been dripping slowly onto the exhaust at some point?
Dave
Post by AlpineRaven » Fri Feb 15, 2008 8:47 pm
could be dripping on main shaft at the front of the gearbox, have you noticed any 'leaks' on front or rear of the gearbox?
90brumby
Post by 90brumby » Sat Feb 16, 2008 12:23 am
this gbox has done a lot of ks so yes it may have a few leaks that drop onto the exhaust or it probably not possible but it could b leakin out the back onto the tail shaft n ur just not noticing it
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by Subafury » Sat Feb 16, 2008 11:56 am
remember we saw some smoke coming off the headers when attaching your bash plate- i think it was from the gearbox drain plug.
PeeJay
Post by PeeJay » Sat Feb 16, 2008 7:53 pm
Did you put about 4l of oil into it?
Busdriver
Post by Busdriver » Sat Feb 16, 2008 8:26 pm
Do you have an oil cooler in the radiator tank? Do you have any rubber hoses connecting to the pipes for the oil cooler?
Suby Newbie
Matatak
Post by Matatak » Sat Feb 16, 2008 8:56 pm
its a manual busdriver.
and jsut to confirm. Alex DOES have leaks on the box. but they are not severe or dripping out.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Busdriver
Post by Busdriver » Sat Feb 16, 2008 9:34 pm
Sorry bout that, I got thrown that way by AndrewT referring to a sump on the box, and I didnt think manuals had a sump as such.
Other than it leaking oil, I have no idea where it could be going, but I would love to find out!
Suby Newbie
