Carburetored EJ22 - Pics found
I thought the pipes coming out the front fenders were fakes till he started it up.
That distributor doesnt leave much room for a turbo
Carb and distributor
Hi Ben, this will work on any SOHC EJ motor.
I have heard of it done to a DOHC one in a jetboat although it required serious machining work.
Budgetry restraints have ruled out a side draught carbie for my boat and as I have a spare Weber down draught that will be going on.
They came out on ford motors up to 2 ltrs, I am hoping I can jet it up enough for a 2.2 with no frills.
Tigging my old EA81 adapter plate right on to the inlet.
Budget pffft what budget.
1989 Subaru WonderBrumby II
That would be grand Jono.
Very much appreciated.
- BaronVonChickenPants
Please let us know what you find...I was not aware they were different.
- Ben
Ok, I've just come to an "I'm a dumb-arse" realisation.
The reason this works is that the heads are left/right interchangeable - therefore something needs to be provided on the head to mount stuff like cam gear to the head...
This is a pic of the drivers side head rear
[ATTACH]697[/ATTACH]
And here is the passenger side rear.
[ATTACH]698[/ATTACH]
How does that rubber bung come out?
- DSC05037 (Medium).JPG (49.41 KiB) Viewed 8523 times
- DSC05036 (Medium).JPG (50.91 KiB) Viewed 8524 times
- FROG
had to smack mine out from the inside when i did my heads up last week they just a press fit if you muck it up they not too xxxy from subaru usually got some sealer on it may be a little awkward to remove from outside
Should be able to get my uncle to do it he use to do it to the old VW, still the basic principles.Ben wrote:I can't see any issues with that carb on an ea82. It's pretty simple and there should be enough old skool mechanics around that can do the jetting properly.
cheers i shall be keeeping my out for 1.
Yes ppl are doing things, and those that are die hard fans of this site still find a way on here to share things, like this effort by Phinzinza:Nubaru wrote:This might be a good way to resolve a blown something in my Brumby.
Anyonee;lse done this stuff lately?
Of cor snot. N one is in here
Bernadette Brumby build - post two should be of particular interest. Like any build, several things are often happening all at once so there's no guarantee that all the info is on one post or one page
