Check Engine Light
LongtimeAddict
Check Engine Light
Post by LongtimeAddict » Mon Jan 28, 2008 5:20 pm
89 L series MPFI. Just put in a 2" lift kit last week and since then the 'CHECK ENGINE' light has come on. Had to replace the speedo cable today and whilst under the dash found 2 sets of connectors unplugged. So I plugged them in and now the CHECK ENGINE light is flashing! I have checked all the wiring in the engine bay and can't find anything amiss.
So what the hell is the CHECK ENGINE light? Niether the handbook nor the Gregorys workshop manual mention it.
Is it OK to keep driving? Temperature normal, oil level ok, coolant ok.
Any advise would be appreciated.............:confused:
timmo
Post by timmo » Mon Jan 28, 2008 5:35 pm
You probably disturbed a dodgy connector, usually the cause of trouble codes. Look on you ecu under the dash theres a LED that flashes. The connectors you connected were probably the test mode ones. Here are the codes and how to clear them: (you'll be looking at the ones for '87. Also look here http://www.ausubaru.com.au/showthread.php?t=3370 If this doesnt help theres plenty more infor out there try a search
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
LongtimeAddict
Post by LongtimeAddict » Mon Jan 28, 2008 7:01 pm
Thanks Timmo. Looking thru I can see a green LED flashing seven short flashes, so now I am reallllllllllly confused !
Captain Obvious
Post by Captain Obvious » Mon Jan 28, 2008 7:52 pm
what color are the connectors you plugged in??
Post by Gannon » Mon Jan 28, 2008 8:04 pm
There are 2 pairs of connectors, 2 terminal Green ones and Black 1 terminal ones.
The green ones are for checking timing, and displaying current codes. The black ones are for reading stored codes. Connect them both and code memory will be erased.
For normal operation, leave both sets disconnected.
7 short flashes shows what model you have. If you look it up i think it will tell you its "EFI Non Turbo Australia"
LongtimeAddict
Post by LongtimeAddict » Wed Jan 30, 2008 10:02 am
Thank you everybody. Lean Fuel indicated and I found a rubber tube from the air intake had come loose. All fixed. Once again thank you, it saved me a lot of money! :)
Post by steptoe » Wed Jan 30, 2008 7:19 pm
it is moments like this I start to think these ecu's aint too bad if they tell you what is wrong, you understand and can fix !
