The Brumbyrunner Project
Moderator: brumbyrunner
Xtreme_RX
Post by Xtreme_RX » Mon Dec 24, 2007 11:56 am
Everybody is working Christmas eve........
http://www.subiparts.com.au
0438 887 746
Wilbur
Post by Wilbur » Mon Dec 24, 2007 12:13 pm
Yep include me as working....at least until 2pm anyway.
What I was trying to say about the suspension was say you get 12 inches of total travel. Do you then work out you want 4 inches up travel and 8 inches down ?
brumbyrunner
Post by brumbyrunner » Mon Dec 24, 2007 1:19 pm
yeah pretty much...
Settlement Creek Racing
brumbyrunner
Post by brumbyrunner » Fri Dec 28, 2007 6:24 am
This is a work in progress. Got a small waterleak that drips onto the themostat housing. Where would that be coming from? Must be behind the timing cover. I wont buy an engine this old again, regardless of the low kays.
Was hoping to start on the 5-stud already but had to walk home yesterday after the fuel pump died. Anyone know whats the output of the stock MY lift pump?
SUBYDAZZ
Post by SUBYDAZZ » Fri Dec 28, 2007 7:20 am
brumbyrunner wrote:This is a work in progress. Got a small waterleak that drips onto the themostat housing. Where would that be coming from?
Water pump or the bypass pipe under where the A/C is, if that is there on that motor. Does it only leak while car is running or does it also leak when not running?
SUBYDAZZ
Matatak
Post by Matatak » Fri Dec 28, 2007 10:22 am
The water pump could also be suspect..
but i aitn sure where it is on an EJ20G i no that EJ25 its right above the thermo housing.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
brumbyrunner
Post by brumbyrunner » Fri Dec 28, 2007 4:04 pm
I bet it's the water pump.
At least if I replace it now I know it's right.
I have tracked down a '99 STi front cut that I might swap to. Have to have a look at it first. Has 4.444 diff but wrong gearset of course.
Wilbur
Post by Wilbur » Fri Dec 28, 2007 4:09 pm
Your going to look at it.....with a telescope I presume :D
brumbyrunner
Post by brumbyrunner » Fri Dec 28, 2007 8:22 pm
Lightning_Silver_RX wrote:Your going to look at it.....with a telescope I presume :D
I have friends in high places :)
Turns out its a 2002 STI.
Still waiting on the gearbox ratios.
Outback bloke
Post by Outback bloke » Fri Dec 28, 2007 9:05 pm
Tell me more. Very interesting. Local to me?
brumbyrunner
Post by brumbyrunner » Sun Dec 30, 2007 9:33 am
SUBYDAZZ wrote:Water pump or the bypass pipe under where the A/C is, if that is there on that motor. Does it only leak while car is running or does it also leak when not running?
Bypass pipe was rusted out and has been replaced with hose.
Does not have a/c anymore :)
Only leaks while running and now it has stopped leaking.
Matatak wrote:The water pump could also be suspect..
It's in the same place. Just the drama of pulling it out.
BYB-01 wrote:Tell me more. Very interesting. Local to me?
Sure is.
brumbyrunner
Post by brumbyrunner » Tue Jan 01, 2008 11:49 pm
Started on the Crossbred Performance 5 stud conversion today. I'll try to get some pics up tomorrow.
There is no doubt about the quality of the design and engineering. Everything fits with tight tolerances with all new bolts and brake lines included. It's a shame that Gee decided to pursue other interests instead of continuing to find ways to improve our old Subys.
I'll be running some single spot calipers and ventilated discs on the rear with 2 spots on the front and some old 14" Liberty rims with 28" tyres until my new stuff shows up.
It's been a busy couple of week of shopping. So far I've got-:
15" alloy wheels.
4 spot front and 2 spot rear disc brakes.
Early RA gearbox with the low ratios.
Suretrac viscous front LSD.
and a 4.444 R160
Now I just have to get them here and bolt them on.
Turns out the fuel pump had sucked some fillings out of the tank and one was holding a valve open. Working perfectly again. I measured it pumping over 3 litres/min. It's good to know they are serviceable but I've got a filter before the pump now.
Point
Post by Point » Wed Jan 02, 2008 9:16 am
i thought that to fit the 2 spot fronts you needed 15" wheels and for the 4 spots you had to have 16" wheels?
good to see you've got the box you were after.
brumbyrunner
Post by brumbyrunner » Wed Jan 02, 2008 10:41 am
Point wrote:i thought that to fit the 2 spot fronts you needed 15" wheels and for the 4 spots you had to have 16" wheels?
So did I and thats why I was looking for 16"s but it must depend on the wheel offset. The rims and brakes that I've bought have come off the same car so they must clear.
I doubt I'll be able to get my 2 spot fronts under my old 14" Liberty rims but at least I'll be able to move the car around without brakes untill my new stuff arrives.
If anyone is interested, the Crossbred kit changes the rear wheel mount surface (WMS) by +1" each side. Of course this means bugger all as the rim offsets are so different between MY and Liberty.
brumbyrunner
Post by brumbyrunner » Wed Jan 02, 2008 10:38 pm
Here's a before and after shot. Different sides but you get the jist.
Rear shot showing pass. side done.
It rained a bit today. Good opportunity to be in the workshop.
brumbyrunner
Post by brumbyrunner » Wed Jan 02, 2008 10:49 pm
I used these Sherpas on the old RX racecar. They're a fantastic allrounder. Pity Firestone stopped making them. Notice how tiny they look under the ute.
Thats the easy part done. Now for the front...
seagull
Post by seagull » Thu Jan 03, 2008 12:30 am
those short stubs in the diff are very week , is this the diff you will be running ?
brumbyrunner
Post by brumbyrunner » Thu Jan 03, 2008 7:06 am
seagull wrote:those short stubs in the diff are very week , is this the diff you will be running ?
Yes, for the time being. Do you think the later, push in DOJ style are stronger? I am worried that they might pull out at maximum rebound.
These arn't the hollow open diff type but the solid, different each side, plate LSD type.
Captain Obvious
Post by Captain Obvious » Thu Jan 03, 2008 8:29 am
nice work, the sherpa were a great tyre and it is a pitty the stopped making them!!, what size rims are you going to be running with the 5 stud???
brumbyrunner
Post by brumbyrunner » Thu Jan 03, 2008 10:18 am
89rsturbo wrote:what size rims are you going to be running with the 5 stud???
Initally I was looking for some 16" Outback/Forester rims but I was concerned about their durability. I like the Superlite 16x7 as suggested by Brett but can't get one to test fit (and havn't actually got anything to test fit it on yet) so will have to hold off on that. Mainly was going 16" because I have some expensive 30" rally tyres doing nothing and the added bonus of bigger brakes.
Then some 15" forged alloys came up at the right price so I'm using them instead. I'll put the 30x9.5" MTR onto them. Don't want to spend up on rims because eventually I'll change to 5 stud VW.
Return to “Brumbyrunner”
