Has any one a 3" lift on there liberty wagon ?
I about to do this but not sure if its a over kill , feed back would be good on this one guys .
car is ready for the mods & new turbo motor .
seagull
seagull
- Outback bloke
Grant 91 wagon 3" lift
Dave 91 Wagon 3" lift (Previous wagon was 3" lift)
Daniel 93 wagon 3" lift
Me 95 wagon 3" lift (previous sedan was 3" lift)
I have also sent 3" lifts to a heap of people world wide that have Liberty wagons or sedans. If all you do is the 3" lift then it is pretty much just going to look like an Outback. If you do the Outback strut and spring lift thing, then it is looks like a lifted Outback which is very common.
If you go for a turbo motor you will have a few issues with the IC. They are not major problems but there is a few things that have to be modified.
- BaronVonChickenPants
- Outback bloke
Or have a look at Ben's gallery at http://images.benandmichelle.net/thumbnails.php?album=2 . You will find a few pics of lifted Libs in there.
- vincentvega
- Outback bloke
Yep. We have put them in a few cars now instead of using lifted springs. You need to know that you will change your CV angles by doing so though. It might not sound like much, but if you use them, Outback struts and lifted springs you are lifting by about 85mm without even taking in to account the lift kit.
up date
up date on the liberty
most of the lift now done ,> motor and auto in >dash back in with just about all the wiring done .fitting a oil cooler for the trans
fabing a ally bash plate for the under side of the motor & trans .fabing a push bar for the front , some place to mount some lights & save the radiator should skippy come my way .
been doing some silly hours on the wagon
[/b]
[/b]
- vincentvega
