Best spot to go through firewall. 'L' series
BENduro
Post by BENduro » Fri Sep 21, 2007 7:23 pm
I need to run a charge cable from the rear of the 'L' to the start battery, through the firewall. I have absolutly no idea what I am doing and would greatly appreciate some help.
Is there an existing hole to go through, if so where and how do I find it/get there:confused:
Where do I go if the above is not the case:confused:
Cheers in advance;)
stamp_licker
Post by stamp_licker » Fri Sep 21, 2007 8:27 pm
i went on the passenger side,there is a rubber groment that the wiper wiring and a/c wiring comes thru.You can see it from above .Push thru the grommment and it comes out near the passenger kick panel .You can lift the carpet up and feed it to back under the carpet.
Building a hardcore postie:D
BENduro
Post by BENduro » Fri Sep 21, 2007 9:08 pm
Thanks mate...Sounds like a piece of piss. Betcha I make hard work of it though;)
BENduro
Post by BENduro » Sat Sep 22, 2007 11:57 pm
All done and thanks for the heads-up...Worked out great:)
