H6 'VVT' fit SVX EG33?
Post by steptoe » Mon Sep 17, 2007 11:55 pm
a mates father has asked me if i know if this has been done/will work. (hey, i only drive a Brumby - I DO NOT KNOW) but someone in here may know , like Steve and Daniel
brumbyrunner
Post by brumbyrunner » Tue Sep 18, 2007 12:07 am
What do want to know?
If the variable valve timing from the current model 3.0 H6 will retro-fit onto the older 3.3?
No chance in hell.
But why would you want to?
BaronVonChickenPants
Post by BaronVonChickenPants » Tue Sep 18, 2007 12:16 am
In theory if you can get hold of a Gen 4 EZ30 it should fit as it's a physically smaller engine, but I have no idea if it will directly bolt up to anything, to be honest I doubt it.
But all you're really going to gain is an engine with the same power and slightly less weight and a major wiring headache.
Jordan.
Ben
Post by Ben » Tue Sep 18, 2007 7:21 am
I'm with Jordan, but think that it all would directly bolt up. Also, as Jordan said you would gain nothing in the conversion.
That said, if the motive is to find a cheaper than EG33 replacement for a dead motor I think the install, unless completeable by your mates father in entirety would be more expensive than getting a full rebuild on the dead engine.
Please watch before posting!
FROG
svx
Post by FROG » Tue Sep 18, 2007 7:50 am
http://www.subaru-svx.net/forum/forumdisplay.php?f=4
these guys would be able to help you out id imagine
Post by steptoe » Tue Sep 18, 2007 2:37 pm
It was an idea that someone entered into his head. I thought I'd ask. I thought someone may have said EG33 is belts (at the front?) and EZ30 is chain drive (at the rear of engine??) Is it electronic ? not oil driven like sister (SPIT) company nissan?
engine is sweet
also sounded lke one of those hair brained ideas like an EG33 into a Brumby - and that sounded like a piece of cake for Daniel
brumbyrunner
Post by brumbyrunner » Tue Sep 18, 2007 3:13 pm
steptoe wrote:It was an idea that someone entered into his head. I thought I'd ask. I thought someone may have said EG33 is belts (at the front?) and EZ30 is chain drive (at the rear of engine??) Is it electronic ? not oil driven like sister (SPIT) company nissan?
engine is sweet
EG33 is timing belt. EZ30 is timing chain. Both at the front.
Did you just want to put an EZ30 into an SVX (unlike my original interpretation)?
Should be very do-able with a huge improvement in centre-of-balance.
Post by steptoe » Tue Sep 18, 2007 3:36 pm
ooh sacre bleu, downsize ?? NO WAY !! The idea tossed was 'just' use subaru equivalent of VVT off the EZ30 onto EG33 to chase more top end grunt
waiting for Rising Sun Steve to say he has done it !!
Ben
Post by Ben » Tue Sep 18, 2007 3:52 pm
steptoe wrote:The idea tossed was 'just' use subaru equivalent of VVT off the EZ30 onto EG33
As Stuart said, not a chance.
Post by AlpineRaven » Tue Sep 18, 2007 7:39 pm
Wouldnt the bolt on to the transmission be different?
