electronic distributor wiring
can anyone tell me how to wire in the electronic distributor in the ea81
the old points one just had the one wire coming off to tell the coil when to fire
but the new one has 2 wires coming off and im not too sure what to do with them
any help would be great
cheers
Johnny
cheers
Johnny
Hey Yo
I'd also like to know the set-up as that be my next/first mod after the Christmas run down south. If anyone Perth side has a spare or knows of one around I'd surely be interested.
Thanks
Kaffine
Thanks
Kaffine
2006 the year of the Subaru
sofar completed: Rear bumper replaced, central locking, next weber conversion.
Nah, I went and checked under my bonnet. Unless it's possible to reverse wire a coil, I'm not sure about polarity switching with coils.
Hmmm, that makes me think of something else. I installed a tacho, and the only way it would work was to wire it to the positive terminal when the manual said negative terminal. Makes me think even more that the coil is wired back-the-front.
'87 Targa Brumby
'83 Sherpa
'83 Sherpa
cheers people...
ill wait for someone to check in da morning... well later in the morning
and wouldnt you know it... had to go help a mate jump start his car tonight... but the soob wasnt going 8O and i had parked the twagon in so i couldnt go in that either 8O
so i had to take the ute instead, but i took bluesteels battery with me so there was at least some part of a soob to the rescue
oh and xaymaca... at least now i know it wont fry if i wire it up wrong
I have to blatently say I'm Correct
Yellow is points to (-) coil and Blk/Wht is to (+) coil and battery supply.
The secondary is grounded via a gap to the (-) side I think, so if you hook up
+the wrong way, it will work, but the voltage spikes on the (+) side would be crazy I expect.....and start affecting other things.......
I multimetered my coil today and I was getting a nice 13.8V to the negative of the coil... How healthy.
I spoke to an autoelectrician about the effects and he said with the earlier type of coils I will just get a weaker spark. Hopefully I will be able to get a bit more goodness after switching it over!
'87 Targa Brumby
'83 Sherpa
'83 Sherpa
