ej22 engine mods
tassyraider
ej22 engine mods
Post by tassyraider » Fri Sep 14, 2007 12:26 pm
hi all
just about to build up a ej 22 block,ej18 heads,18 injection gear
has any one done this,if so what pros/cons about this conversion
the reason for 18 injection as my wireing is done
cheerz mick
current ej18 awd targa brumby
95 impreza awd sportz wagon
mattl200
Post by mattl200 » Fri Sep 14, 2007 10:35 pm
probley want to use an ej22 computer otherwise the engine will lean out bad
SuBaRiNo
Post by SuBaRiNo » Fri Sep 14, 2007 10:58 pm
Wouldn't using ej18 heads be a down grade?
Dave
tassyraider
Post by tassyraider » Sat Sep 15, 2007 7:14 pm
mabee same heads or low compression heads or high comp heads
put 22 injectors in when assembled unless differnt sizes
Post by El_Freddo » Mon Sep 17, 2007 5:36 pm
SuBaRiNo wrote:Wouldn't using ej18 heads be a down grade?
Dave
Might have a smaller chamber would probabily = higher compression depending on what the cam timing is doing. The valves may be smaller too - you'd want to check this out.
On old holdens a trick to get them moving with the old sixes was to get a head from an engine size below (or two below) what you have - these have smaller chambers and help easily increase compression, with a good cam etc you'd have a sweet performance engine...
I reckon there'll be problems with the computer and leaning out, it may adjust itself enough to get by but could be outside the fuel delivery range. Larger injectors may help.
My 2c
