How to run a waeco fridge with ignition off???
BENduro
Post by BENduro » Tue Sep 04, 2007 11:39 am
BYB-01 wrote:You can get a good quality battery box from Battery World for around $60 that comes with a cigarette lighter attachment. Add in another $200 for a 120 amp hour deep cycle and the solonoid/dual battery set up and you will never have a problem with it.
It is an excellent way to do this as when you go camping you can just lift it all out of your car and sit it in the tent or shade some where. Simply back the car up to it every now and then to charge the battery up.
Thanks, will probably go this way and am interested to know approximate charge time...How long would I need to run the car each time and how long a drive would it take to recharge fully (sealed 100amp hour).
vincentvega
Post by vincentvega » Tue Sep 04, 2007 7:36 pm
assume a 1/2 flat battery
50 Amp Hour
At 50A charge rate it would take 1 hour.
At 25A charge rate it would take 2 hours.
ie you need to accurately know the charge rate to know how long it will take
BENduro
Post by BENduro » Tue Sep 04, 2007 7:51 pm
Thanks vincentvega.
Have put a bid in on this ebay item: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :IT&ih=012
Plan to wire this from the vehicle battery through to the portable battery box with 100amp hour sealed century batt'. All up cost should be about $500, providing I can do the wiring...You guys will hear from me re the wiring as I have absolutly no idea:confused:
Wilbur
Post by Wilbur » Wed Sep 05, 2007 8:48 am
Those ones are ok, but I doubt there will be enough wire in the kit to reach the rear of your car. I also wouldn't bid much higher than that.
BENduro
Post by BENduro » Wed Sep 05, 2007 9:45 am
Didn't think about the wire...Just assumed that they would provide enough.
So you don't beleive they are worth the $360RRP that was quoted in the ad?
Xtreme_RX
Post by Xtreme_RX » Wed Sep 05, 2007 10:30 am
BENduro wrote:So you don't beleive they are worth the $360RRP that was quoted in the ad?
Nope...... I sell Narva/Projector equipment at my work.....
http://www.subiparts.com.au
0438 887 746
BaronVonChickenPants
Post by BaronVonChickenPants » Wed Sep 05, 2007 1:15 pm
Go into a jaycar/leading edge electronics and (assuming you don't get a trained monkey) ask them about solid state relays.
The amount of power these things can handle is crazy, no moving parts, no welding or magnetising of contacts, very impressive, take this fella for example.
Jordan.
BENduro
Post by BENduro » Wed Sep 05, 2007 1:27 pm
Is the jaycar alternative you suggest used in place of the isolator?
Might have to investigate further:???:
Phizinza
Post by Phizinza » Wed Sep 05, 2007 3:13 pm
To add a little to what Vincent was saying.
I have a ammeter and I notice even with my EJ alt (70amps?) when the battery is too flat to start the car it only charges at around 24A for about 15mins then drops back slowly to 15A over another 15mins and by the end of the hour it's back down to 7-9A. So although the alt is 70A charge, you'll be hard pressed to get that much out of it unless you have a few hundred Ah of battery and they were completely flat.
Post by BaronVonChickenPants » Wed Sep 05, 2007 6:01 pm
BENduro wrote:Is the jaycar alternative you suggest used in place of the isolator?
Yeah thats the idea.
Jordan.
stamp_licker
Post by stamp_licker » Fri Sep 07, 2007 6:50 pm
Jaycar sell a few different isolators around the $100 mark.I brought 5Metres of wire ,can't remember the guage,and terminals for around $30 to $40 to run abattery in the back of a L of them.For around $150 + battery cost you ccould be setup.
Building a hardcore postie:D
BENduro
Post by BENduro » Fri Sep 14, 2007 11:59 am
Righto, after a lot of research and delliberation I have decided to take the easy road with one of these:
http://www.sidewinder.com.au/page146.html
mated with a 100amp hour AGM battery...Not sure of brand yet:confused:
Opinions:???:
Wilbur
Post by Wilbur » Fri Sep 14, 2007 12:10 pm
If your buying off ABR why not go an amptech - http://www.sidewinder.com.au/page90.html
I've got one in the tray of the hilux and its holding up quite well.
BENduro
Post by BENduro » Fri Sep 14, 2007 3:37 pm
Yeah, saw those...I reckon shipping would be a killer though, Queerland to Vicco:(
Just joking about the queer bit.:)
Wilbur
Post by Wilbur » Fri Sep 14, 2007 3:45 pm
1300 228 837 will find your local supercharge distributor.
