Engineers
That's cool. I know you've spent a lot of effort. Kind of seems like you've had to do too much.
Best bet is to use Imageshack http://www.imageshack.ws/, though others might recommend other sites.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Previous rides:
- Ben
No worries Nathan, I knew what you meant
Bratgeebah - I am loving your kit, sounds like you have really made an effort to make it all work and work well. I sincerely hope that you are rewarded well for your efforts in sales of your product. One wee thing I ask though (damn I hate the 'but' bit) you call it Billet cromo - it isn't...
A Billet is a big arse chunk of raw alloy that is to be fed into the extrusion machine. The bit that comes out the other end, a sized piece of alloy is no longer a billet, it is an extrusion, or barstock. Calling a product as 'machined from billet' is a wanker hotrodder parts thing.
I will go one to say though, my tech teacher who made race car parts in the 70's would buy chunks of aluminium alloy straight off the billet in order to make some parts as extrusions in Australia at the time were not available. Nowadays you can buy anything in any size. Capral has actual staff whose job it is to sell specific extrusions to suit a market!!
Oops, sorry about the rant, carry on!
:oops:I didn't know that. The hubs are made from 4140 crmo and the backing plate boss's are machined from an extrusion.
Here they are look in the brake conversion update album.
http://community.webshots.com/user/tmac746
Gee.
Gee.
- Ben
Cripes!!! A grand!!!
I guess after that the next weakest link will fail...
I did some drawings recently of the new and improved radius rod mounts I want (think mega-lift patrol parts for style) but I am not sure how my little lathe will handle it - once I get all moved and set up I'll start to buy some larger alloy steel sections and do some experimenting...
I planned for 20mm EN26 for the radius rods, I think 25mm is possibly a little on the large side especially considering they will be stronger than the lower control arms, and everything else on the car...
Have a look under the back of a wider body or later Camry, the toe-in is adjustable.
Those arms are approx the same size as the radius rods.
I was looking at cutting the rods in the middle & getting a thread machined into it to fit these parts on.
Current rides:
Previous rides:
Previous rides:
- vincentvega
muddy the problem then is going to be that you will tear the trailing arm mounts out of the body. unless yours are reinforced?
couple of examples for you.
BYB BBQ justin had an off in his RX. Hes running XD falcon trailing arms, the arm survived but he mangled all the mouting points in the body.
DI trip curly's daughter drove his car into a tree. stock trailing arms > all that was damaged was the trailing arm.
my point is if your going to run heavier arms you better look at reinforcing the mount
wouldnt it be better to build a radius rod that was actually designed to "break". If you had a sliding join in it for your adjustment that was just clamped in position it would give you the adjustment and then when you did hit something it would "break" but all you would need to do was slide it back to the correct position.
