EA82T boost pressure ?
figuring std boost pressure is about six psi, does waste gate begin to open just above like at 7psi or does it wait until 8 or 9?
another LPG conversion calculation 'ere
Standard boost pressure is 6.5psi
I assume that the wastegate would start to open before 6psi and would be fully open at 6.5, depending of course on engine rpm and load
You should also be aware of waste gate leakage… a dirty word I know however something to be aware of, as it unfortunately happens.
- discopotato03
Jono turbocharger waste gate diaphrams are designed to crack the gate open a little before the desired boost pressure is reached . This way the vent path swing valve has a chance to regulate the turbine speed and hence compressor revs , boost pressure is merely a measure of resistance to airflow . Manufactures in the 80's liked it this way because rapid boost rise often means rapid torque rise (well designed turbo engines can easily double their torque outputs in 500 RPM) , ok for petrol heads but not at times smooth or easy to control on a tight bend especially in the wet . Modern turbo engines have much more linear power delivery and more sophisticated engine management and turbos make a big difference .
Many turbo cars nowdays use electronic control of the wastegates pressure signal and this is mainly about keeping the gate shut until the regulated pressure is reached . In other words it gets around the mechanical limitations of the spring/diaphram waste gate actuator . I believe this is what the 4 plug RX turbo cars have so very likely they'd be a little more responsive than the 3 plug cars .
Jaycar make a very interesting kit that controlls a boost solenoid but its signal is supplied from an injectors duty cycle . It is far and away a MUCH faster and more accurate means of boost control signal than a MAP sensor based one . I intend to build one along with their Digital Fuel Adjuster so that I can have some say over injector size/AFM size and retain a std Subie ECU . Thank god for basic engine control systems from the 80's .
Cheers A .
Cheers A .
I noticed while driving since i hooked up the WGDS, (i previously had it bypassed)...
The WGDS operates at partial throttle, you can hear it clicking, and full throttle until about 2400rpm, then it stops clicking.
This is exactly what you just described, it ensures that the wastegate stays fully closed until full boost is reached.
Although i noticed apon accelerating that boost spikes to about 8psi and then settles to 6.5 once 2400rpm is reached. Im guessing that this is because i have a free flowing exhaust and i reach full boost (6.5psi) at about 2200rpm
It'll be trial and error and fiddling for me, and more questions posted as I learn or discover more.Noticed green boost light during free revving in neutral or park does not glow until about 4500 rpm
!! . BUT took it for a few laps up the road to clean the rust off the discs and notice boost light at about 2500rpm
. Know someone with a boost gauge not in use, so off to knick that soon I'd say ...
Yeah 80's and 90's turbos were a bit umm harsh, TX5 and oh the Cordia just got rated as worst performing car safety wise. NSW coppers used to torque steer themselves off the tarmac with these !!
while free revving the turbo does not boost up, engine needs pressure to wind up the turbo..hence y the bost light does not go on till late in the rev when free revving...when driving there is pressure on the engine hence the boost rising when and how it should b
dave
dave
- discopotato03
Yes the cops got into hot water with the Cordias and VLT's . People who aren't used to turbo torque tend to stand on the go pedal and wonder why the cars spins wheels or torque steers at not terribly high revs . Its suddenly a whole new world of how to balance throttle inputs and adhesion levels .
I haven't looked into how the 4P RX does its solenoid regulation as there's a few ways to go about it ie restricton and signal bleeed or the total block method . Either way the Jaycar system is fast/modern/cheap and makes you learn how to identify/solder/test circuits . They supply very easy and simple to use instructions in all their kits . I'll find out tomorrow .
Cheers A .
Cheers A .
