ej22 no go
- stamp_licker
ej22 no go
This one got me stumped where to start looking .Rebuilt motor fitted hooked up the wiring etc,turn the key small bomp like its gunna fire then nothing just keep on cranking nothing.Connect check engine plugs and no codes it just keeps on flashing and don't stop.Where do i start to look ?
Building a hardcore postie:D
at the timing maybe.
or the fuel is it actually being pumped in to cylinders
check the spark to
if u got a spare plug take a lead off then shove the plug into it and rest it against somwhere then crank it and see if its sparking.
at work we have a tester that slots into the fuel injector connectors and flashes with each pulse so i dunno how to test them without somethign like that
maybe a test light connected up then hold it on and get somone to crank it for u
those wuld be the three first things id try starting with spark, fuel see if its pulsing, then the timing if theyre both ok
check the spark to
Wagon is no longer....
- stamp_licker
well then the timing hopefully that is right
and im guessing the injectors wuldnt eb the cause as i cnat see all 4 being completely blocked
otherwise something to do with the ECU maybe not functioning right which wuld be out of my league i dont no nethign botu them
- stamp_licker
Hope you didn't do what we done, align the timing marks on the cam pulleys with the piston mark on the crank..
Why put piston marks on the cam pulleys anyhow?? Only need TDC on the crank really. Ok, we were just stupid and Subaru done nothing wrong.
- stamp_licker
Yeah i wish someone would do an awesome write up with pics on the timiing belts for ej22s....
I have done them successfully twice... i guess by pure luck... 3rd time was a balls up... and it kept doing exactly what your describing... took someone who knew what they were doing to fix it... 10 minutes later everything was sweet.
Dave
Dave
Engine light will do nothing if it wont actually start.
Dave
Dave
- Outback bloke
Yeah but to pick up an engine fault it needs to start. So yeah u can check the codes but it's not going to tell u why it isn't starting now... just anything that was wrong last time it was started... or nothing at all if the Battery or ECU has been dissconected for a bit.
Dave
Dave
- stamp_licker
yes indeed.BYB-01 wrote:Will, the timing is set off the notch in the "star" and not off the arrow isn't it?
The day was saved by the jedi master Subie won kenobi.He arrived in my garage and had the prob solved in minutes.Timing maybe out it is,The noch not the arrow.I had pulled those covers twice checked and checked .With a wave of his jedi mind the covers were off again and fixed in no time.Thanks heeps Dave.I owe you big.
good stuff....now bring on the action!!
dave
dave
- Suby Wan Kenobi
