code 45 - Pressure Sensor or Exchange Solenoid
I have never had this come up before and no idea where they are located on the engine or what they do - let alone fixing them.
I figured it is around the idle switch area, as there was a problem in this area as well, but I am not familiar with the parts or names. ( engine was running with no probs when installing, so no need to know everything until I needed to I guess)
Has anyone come across this / these before and are they adjustable, or just have to replace them ?
I have done a search, but nothing seems to come up in the forum threads, but will refine the searches a bit more.
I also have downloaded the manual, but so far no luck in finding the things in there.
I am not sure , but I assumed that the pressure sensor was only on auto transmissions - so does this mean that the Exchange solenoid is instead of the pressure sensor?
any help or comments are appreciated,
cheers,
Chris
