Guards
- subusurfer
Guards
Gday, does anyone know where i can source some black plastic inserts which go over the guards, in adelaide?
- subusurfer
- Bratgeebah
- Bratgeebah
It's an extruded, flat (with a profile on its cross section) wide(about 2"
two widths available) strip of black rubber (flexible on its length) that you cut to length and place around the wheel arch. You see it alot on old Landcruisers and Patrols etc. and I've seen it on a few Subarus on these forums.
4wd outlets sell it. It comes with a 1.5mm wire which is pushed thru/along the rubber, hence it holds its shape very well. I've seen the clark rubber stuff,buts its not made the same i don't think.
Yes I used it, as the desert rats do have a wider stance (offset) not just bigger tyres.
comes in 2 widths, you'll want the shorter, um 38mm?
- The Scoobyside
