Should you run special head gaskets with Dual port heads? I.e can you use standard head gaskets?
Thanks
Matt
Head Gaskets
Head Gaskets
"Claudia"
"Claudia"
By dual port heads do you mean ea81 with the divider in the exhaust outlet?
The head construction is the same as the heads without the divider, normal headgaskets should be fine (unless its an ea81t)
Make sure you use a repupitable brand
Cheers, you are right by the the split exhaust port. I thought they were just wanted to check.
"Claudia"
"Claudia"
Cheers, you are right Suparoo by Dual Port i mean the the split exhaust port, i.e not standard heads. I thought they were just wanted to check.
Thanks
Matt
Thanks
Matt
"Claudia"
"Claudia"
