5 Stud Conversion
5 Stud Conversion
can anyone tell me where to get kits to convert my subi from 4 stud to 5 stud if at all possible
or atleast prices becuase im still not sure if i want to do it
- Ben
You think?Cam wrote:They kinda costly for what you get tho, i guess not a huge market.
Can the rear drums off an early impreza be put on some how?
Try getting brand new brake upgrades of this calibre for other models, I think you'll soon change your mind...
As for the second question, this could be achieved using the Crossbred kit, which discs are a far better option.
- Chris_Rogers
its a lot of fiddling to do. I have done it and I'm still mixing and matching things.
brats kit is the easy way of doing it. I spent $2k on the rear of mine alone doing it. reworking the impreza stuff and new lines etc was the worst part of it. I have XT6 hubs on mine that I imported from the USA ($550) for a bolt on swap. brats hubs are a DIRECT copy of them that he designed and engineered himself. (we compared them when I was in MLB last year.)
the impreza idea isn't legal as it machines the hub down and weakens it.
to do what you want you need:
front:
steering knuckle swapped
lower ball joint needs swapping and the lower control arm modded to take it
mix N match of axles.
legacy struts
rear: impreza brake assy complete. handbrake cables, 5 stud hubs, impreza handbrake or similar (looked at a diahatsu charade one looks like it would bolt in.) and a lot of fiddling/time
front:
legacy struts
No 90brumby
I got these made a while back in Perth.
I have 1 spare as a tempate.
From memory they cost me $100 ea not including studs
Then you have to machine the hubs/drums flat to suit.
Also got a locating lip cut in them,safer.
Remember,they are illegal,use at your own peril.
(tested them out in Lancelin dunes a while back)
- brumbyrunner
- Fury
I also have one of the kits, - which by the way is the best and easiest legal way to go.
I also looked at redrilling the "L" series hub, and purchased a pair of 4x 114.3 hubs, only to be told by an engineer that unless it conformed to either an Australian standard, or modded by a licenced engineer shop ( or someone who has qualifications on paper) can supply a metalergy certificate and documented welding certificate, that it will not conform. Any stud hole that is left unwelded, within 22 mm of the new stud must be welded with apppropriate material ( 40 41 alloy I believe) heated, welded, heated again and slow cooled so the surrounding material is not compramised.
just the metalergy conformation cert was going to be $250 ! quote on welding 4 hubs, machining and redrilling the hubs and new studs was approx $120 each
... and you are still left with small brakes and an engineers certificate to organise.
Gareth's kit is a fair price for the work that has gone into it, will help as much as he can and has no faults that I can find. Mine has been of for about 10 months - a few weeks before the 06 BBQ -
If you are doing the 5 stud thing, this really is the way to go - even though it "seems" a bit more costly than we would have liked, as I too was financially strapped at the time.
At least consider it. By the way, the engineer that I went to had a look at the kit, said it looked like OEM stuff and if involved in a colission, requiring a tear down, that it probabaly wouldn't even be noticed. - as opposed to spacers, redrilling that would.
Chris
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT!
