LSD center into open diff
- vincentvega
Can anyone point me in the direction of info on how to swap a viscous LSD center into an open diff?
I know the info has been posted a few times but search isnt turning anything up...
I need to swap a viscous LCD center from an aus RS into a 3.9 NA liberty open diff.
cheers
cheers
im fairly sure if you talk to andrewt he can give you all the right info, andrew put a rx lsd into his berty diff
Hunter S. Thompson
Hunter S. Thompson
Basically you need to swap the LSD centre into the OPEN diff casing and use that casing in your car.
Heres what I recall from going one a while back.
- Remove back cover from LSD diff
- Remove stub axel bolts (requires special socket, can get from Snapon)
- Remove stub axels
- Remove the two parts that hold the stub axels (these also hold the centre in place) - I forget what these are called sorry
- Remove LSD centre
- Put the centre in a bench vice - remove ring gear (this is what determines the LSD's ratio).
- Put the LSD centre to the side
- Remove back cover from OPEN diff
- Remove stub axels
- Remove the open centre
- Put the centre in a bench vice - remove the 3.9 ring gear.
- Put the LSD centre into the bench vice
- Install the 3.9 ring gear onto it
- DO NOT use a rattle gun to tighten these bolts - they must be torqued up by hand.
- This *might* require enlarging of the bolt holes on the LSD centre. Some models have smaller diameter holes.
- Reinstall the LSD centre with it's new 3.9 ring gear into the 3.9 OPEN diff centre.
- Be sure to use LSD oil not just normal diff oil.
- Your choice which back cover to install, the one with the stick that says 3.9 or the one that says LSD (personally I think it makes more sense to put the one with the correct ratio).
Back when I did mine somebody posted a link to a thread on USMB which had some diagrams.
- Remove stub axels
- Remove LSD centre
- Remove stub axels
EZ30 L series - Monsterwagon
- vincentvega
excellent, thanks guys.
showthread.php?t=4177&highlight=USMB+diff
http://www.ultimatesubaru.org/forum/sho ... hp?t=49919
http://www.ultimatesubaru.org/forum/sho ... hp?t=66430
search words: limited slip diff LSD swap ratio grind
Use the shims that match the casing. This lines the ring rear up with the pinion the same as it was before.
One way to check the allignment is to smear toothpaste on the pinion then assemble it and turn the diff by hand. Disassemble again and check the imprint of where the gears mesh. It should have as large a possible contact area otherwise the diff will whine.
If you want it to be perfect a diff specialist can re-shim the diff to ensure complete 100% allignment.
- vincentvega
I stripped the LSD diff this evening. all came apart no problem.
One question though - how do you remove the pinion shaft from the diff housing? Or are they a mated part?
The reason I ask is i have a guy wanting to convert his diff to 3.545 - I was planning on sending him down the ring gear and the pinion shaft.
I guess i have to send him the whole diff housing so that he gets the 3.545 pinion?
Also - where was the need for the E10 torx socket? Or is this only required for 4.11 / 4.444 diffs?
- vincentvega
- vincentvega
