It is bloody cracked 3/4 the way around on the turbo mounting flange where the weakest point appears to be the inside of the weld of pipe to flange on the outside. The crack is about 8mm below the topside of the flange.
My 'spare' pipe i then #@*&^ discover is cracked too near the oil filter
What is your best advice to repair these ? 36mm inside dia access hole
intend to get a bit of same calibre zaust pipe and practice with my stick welder first.
just because a mate has a mig does not mean he can weld but i can 'use' it
the big crack on pipe #2 i think to weld it up then weld a band aid size strip over it for strength
thought of putting a WANTED notice on EXTREMErx EA82T powerpipe post but no find it under conversions,group buys, general
thanks,
