Duel Range _&_ TURBO..? Can it be done..?
- L-Raiser
Scorpion Low Range Conversion
Ive since discovered that the Scorpion Low Range conversion gearset is only designed to fit 'SERIES THREE' Outback/Forester gearboxes.....
So their kit is useless to anyone with a Series 1 or 2 G/box...
Kaz
Kaz
The later model boxes fit the earlier model engines.
I've got an 00 WRX box fitted to the back of my 93 WRX motor.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
No, the casings aren't that similar.
The later models have 8 bolts securing to the engine, instead of the earlier models 4 (but these 4 still line up) & for the EJ20T, you've actaully got to cut away part of the bellhousing.
But you missed the point. If you want to use the Scorpion kit, you need the S3 or newer box, so therefore, you get a S3 box & bolt it onto whatever EJ motor you have.
Current rides:
Previous rides:
I have this gearbox...
5spd AWD
Dual Range
Hydraulic Push clutch setup
4.111 final drive
8 bolt housing
From a 1999 Outback
Currently bolted to my RS EJ20G (using 4 bolts)
I can probably find the ident numbers if I look hard enough....but from that description can anybody tell me if its a "S3" gearbox and will work with this Scorpion LOW low range kit?
5spd AWD
Dual Range
4.111 final drive
8 bolt housing
From a 1999 Outback
EZ30 L series - Monsterwagon
- BaronVonChickenPants
