How to weld a fuel tank?????
- subarursliberty
So how do you go about it so you don't blow yourself to kingdom come.
I'm planing on buliding a surge tank for it so I don't have it in the boot.
Also you recon cutting and welding a tank is legal?
- subarursliberty
I don't think its illegal to modify a fuel tank. Pretty sure people usually fill them with water a few times before getting a spark close.
Nothing wrong with running an external surge tank tho. As Mike says, the engine bay is a good place. My Mazda has one mounted down near the fuel pump right near the petrol tank. Not sure if theres room in a Suby for this though.
EZ30 L series - Monsterwagon
wash the tank out with water and metho twice,....then just clean ater twice...this will get all the fuel and vapour out and wont go bang..but make sure its bone dry before spark goes near...ive built and modified 2 fuel tanks before and this is the method i used and im stil here.. dave
- subarursliberty
As dave said as per washing and drying, i left mine in the adelaide sun for 2 days before i even looked at the welder.
Just a note of caution, even if your battery is a sealed type, i recommend a battery box. I reckon (in SA at least) there is some CRAZY law about fuel lines and open battery terminals anywhere in the cabin behind the firewall.
Julian
Julian
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
2004 Outback H6
2004 Forester XS
- steve_rising_sun
I have seen tanks go 'Bang' that have been water flushed for 24hrs and dried out etc. Try filling with mig gas or exhaust gas, after flushing for 24hrs minimum. Use maximum caution, people using the same old safe method can one day end up being peeled of the roof.
Last death in Adelaide was about 5 years ago.
Steve
Steve
You must fill tank for > 48hrs(72 hours better) with water(little detergent in it helps...then fill with inert gas(shielding gas, argon, co2 etc). Then you still need to have the tank vented well so if it goes woof, there is somewhere for gas/burn to escape, c02&argon is heavier so vent at top point.
Surge tank under hood, me not think such good idear unless its a drag car than only runs for a minute or 2....heat soak and vapour lock issues under hood will rear thier ugly head....not to mention correctly venting such a surge tank back to existing vapour system.
I like your thinking tho, built in surge system in the tank would be good, followed by external tank and pump near tank level or below in rear of car being next best thing....
OS
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
- subarursliberty
