Needless to say, I can now read my map in the dark:)
My new super interior light
- PeeJay
Got sick of the stupid dull interior light so I made another. It consists of 8 sets of 3 50,000mcd leds with a 47 ohm resistor in series. If I made another I would change the resistors to 42 ohm (perhaps even 39) and angle some of the LEDs outwards to spread the beam a bit more.
good job!
but be very careful with what voltage range you expect to use it with,
i'm guessing these are 3.3V(forward) 30mA, so even with 47ohm you are overdriving them if your system voltage is 13.8v, and car voltage is notorious for spikes into 14v+, which the leds are very sensitive to...ie they shine bright for an instance....then.....oh damn...
my 2c, is that there much safer being driven from a small switching supply in pairs....the dilemma is fitting it in the space.....
- BaronVonChickenPants
- PeeJay
The Vf is 3.4 - 3.8v, current I think is 30mA. I set the voltage for when the car is off because that is when the light is on the most. Even if I shorten the life from 100,000 hrs to 5,000 hours I don't think I'd notice. Originly I had 4 in series with no resistor, but they were much too dull so I had to change it.
I was going to make a remote-controlled brightness control but I've only got 40pin microcontrollers so I didn't bother.
The capacitor idea is good! Will go do that now.
Didn't take a photo of the bottom but looks much the same as this:
http://led.linear1.org/led.wiz?VS=12.2& ... ID=30&N=24
- waggaclint
my big interior light(twin flouro tubes)
and my smaller front area light(one also in the boot), note the burnt plastic cos i put massive globes in it..
