Achieved so far:
88 Touring wagon rolling shell bought
87 EJ20T RX Turbo sedan bought
both stripped to within an inch of their lives (actually the sedan has been stripped way beyond that & is now officially dead)
JDM 4.11 gearbox & diff sold
00 Oz spec WRX gearbox & Oz Lib RS rear diff bought
engine bay of the wagon prepped & repainted.
00 WRX 4 spot front brakes bought
JDM 93 WRX front brakes sold
custom twin core rad to suit EJ20T fittings bought
inlet manifold & cam covers painted for that blingage factor (water/air intercooler & front calipers are next)
nose cut bought to replace some bent panels
rad support modified so rad drops vertically onto mounts
steering column tilt mechanism swapped to later version
WRX ECU mounts remade to fit onto L series ECU mounts
WRX hydraulic clutch master cylinder mounted
WRX brake master cylinder mounted & brake lines modified to suit
new uprated clutch kit bought
factory full skirt kit bought
Tasks remaining to get it on the road:
reinstall WRX engine wiring loom into touring wagon.
modify central locking
finish installing the alarm
finish modifying clutch pedal to suit hydraulic clutch
finish modifying handbrake cable to suit rear handbrake
buy Lib RS turbo rear brakes (got some? pls contact me)
modify RS rear backing plates to fit L series
change suspension
Stuff to do when I can afford it:
modify RX turbo interior to fit wagon (when funds allow)
paint rest of the shell (when funds allow)
get custom swaybars
get upgraded suspension
