Outback suspension lift part
on the scorpian web site theres a pic of outback with 50mm body lift + 20mm suspension lift.
For now i'd like to do the suspension lift part asap,
so is it purely some different springs, ? if so what brand/part no etc?
I'm guessing the suspension lift part does effect alignment, so is there anything on an Outback to compensate this?
Thanks
Thanks
- vincentvega
- Outback bloke
If you go to the http://www.kingsprings.com.au web site you can see the parts numbers there. Front has camber adjustment on the bottom of the strut. The rear has tow adjustment which can improve your camber.
I have got a kit in mine and the spring lift as well. Wheel alignment is good again now since I have replaced all the bushes.
Thanks:p
Any shocky recommendations? currently the ride is very soft, don't know what shocks are on it tho, if still original....but the paint on the springs look newish!
Looking at http://www.kyb.com.au
hmm many options for the outback,(adjustable too,see AGX) guess it depends on how much i want to spend huh?
Oh and I do need to replace some bushes, stabilizer bushs I think are shagged, maybe ball joints?
Should I get aftermarket ball joints or genuine?
I have an Liberty, would like to lift it - do I require Outback or Forester struts? and raised coils from KYB or Pedders? also what other things do I require?
