either that, or sampling the digital inputs at 2xthe max freq is the right approach.What I was thinking was measure the four wheels using interrupts over a set time period (100ms or 10hz).
It will be interesting to see how much steering effect can be ignored....I guess we will find out....
Initially i'm planning on the traction control to be manual, ie 1 button for each wheel, at least until sorting out sensor issues etc..
Also, what shall we think of for failsafe ? ie you don't want it to brake a wheel by accident/fault when your going at 100kph either because of fault or forgeting to switch it off
I am thinking perhaps on a microswitch (or 2) on the gears 1st/2nd so it'll only be allowed to operate whilst in 1st/2nd. What do you think?
futurelec.com.au - yeah, discovered them just a few weeks ago,
ordered the ATMega Dev board and some other stuff.......
Seems we each have a different method for making PCB
I have been using the PRP positive resist/UV exposure method, but since running out of old batch of PRP, have had zero results with the new stuff
Hey, Ben, can you tell me exactly what paper you used for the toner transfer ?
Ultimately, after any prototype stage, we will need to have boards manufactured, just so at least this can be offered to anyone with barely any electrical knowledge.
take a look at http://www.sesame.com.au
hmm, need to find out where to get connectors for the ABS....
