Cooling issue in L wagon
- Ben
General rundown...
EJ20 na motor in an L series wagon. Dual core radiator with EJ fittings, bugger all room between the radiator and the motor. Pair of super thin fans from supercheap. Fans are operated off the factory ecu switch points.
Problem
At idle all is good, temp gauge sits on thermostat point perfectly, about 1/4 gauge.
At anything over 40km/h it is also fine, will sit on 1/4 without problem.
Between rolling and 40km/h the temp gauge rises heaps, up to nearly 3/4 level, doesn't seem to get any higher than this.
I want this thing to run on the beach etc so would like to have stable temperatures at all driving conditions. Do I need to look at having a switch for the fans to be on when driving offroad? As this is mostly where I am going to be driving at those speeds. If I drive slow and it gets hot, just stopping for a few minutes is enough to cool it down!!
Problem
- Outback bloke
Prolly a stupid question but you haven't got the polarity arse about on the fans have you?
What thermostat have you got?
There is a few things that I would look at trying.
First off, make sure the fans are spinning the correct way. Then try an old thermostat with no guts in it. Last resort would be to have the fans hard wired to a switch.
- Ben
Nope, thats fine, air blows the right way...byb555 wrote:Prolly a stupid question but you haven't got the polarity arse about on the fans have you?
78° replacement from repco with 3, 4mm holes drilled in itbyb555 wrote: What thermostat have you got?
Had a thermostat with no guts, ran too cold on the highway so put the working one back in. When it had no guts it had the same heating up at low speed problem. Radiator came from Wes's L series and was fine there.byb555 wrote:There is a few things that I would look at trying.
Maybe cheap fans really are shit?
cool
Hi Mate
Try changing the coolant for a stronger one like 90 grade.
Wire up the fans with a remote switch , but makw sure that there
wired on the ignition side so they dont run when the cars turned off.
A large oil cooler would help.
The thermostat of choice is as low a temp as you can get
remembering it does effect the fueling in the car.
Cheers Pete
Cheers Pete
- steve_rising_sun
Which sensor are you using for the dash gauge?
I know there's a separate one for the ECU, but the one for the dash gauge on the EJ's reads a different range to the EA version.
EJ sensor will make the L series gauge read at about 1/4 at operating temp & I think at 3/4 you're well into the red.
Others feel free to correct me if I'm wrong.
I ended up welding up the hole for the EJ version & adding a bit of meat around it & then drilling & tapping for the L series sensor. This only makes the dash read correct though.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Previous rides:
- Ben
I have an L series sensor in the radiator replacing one of the old fan switches which are no longer required.wagonist wrote:Which sensor are you using for the dash gauge?
I don't know how the older EJ's work, but my engine has a sensor which sends signal to both the dash and the ecu - I can't replace it at all.wagonist wrote:I ended up welding up the hole for the EJ version & adding a bit of meat around it & then drilling & tapping for the L series sensor. This only makes the dash read correct though.
- Ben
Al, you wouldn't have a part number for that would you?jzk25 wrote:Put a genuine themostat in it, aftermarket are just shit for red motors. Is the heater core OK? Core blockages or no heater circuit at all will cause problems.
You don't want to overheat a late engine continuously, the tin foil headgasket won't like it.
The joys of conversions.
What about a VIN to suit an MY99 impreza, the local subaru dealer just stares blankly if you want a part and don't have a VIN...
I need the following bits -
AC Compressor (startin to get hot down this way
Set of Plug leads.
Thermostat.
The early EJ's (Mine's a 93) had 2 sensors side by side in the pipe. Makes it easier for me
I got an NA EJ A/C comp when I got my donor car.
It will fit, providing you get the EJ20T brackets that bolt it to the motor. I needed those because of the water/air intercooler pipes. Air/air might not be so picky.
& yes, I've got to get the EJ pipe ends fitted to the L pipes as well yet.
Current rides:
Previous rides:
Previous rides:
