You young punks of today wont listen
KERAZY
Post by KERAZY » Sat Jan 13, 2007 12:19 pm
should mount the radiator between the rear panel and the ute tray, have some vents to direct airflow into it? It's out of the way, and it'd look cool :D
Post by Gannon » Sat Jan 13, 2007 5:14 pm
Is the motor gonna be anything like this....
Post by AlpineRaven » Sun Jan 14, 2007 1:44 pm
Suparoo wrote:Is the motor gonna be anything like this....
Man.. that is an sexy beast *drools*... it wouldve pulled your hair off ya head!!!
Is that in Australia or what?
Post by D3V1L » Sun Jan 14, 2007 10:22 pm
Omfg!!
*droooooooools*
:d
smoov
Post by smoov » Sun Jan 14, 2007 11:45 pm
awesome!!!
1998 Subaru Legacy GTB
steve_rising_sun
Post by steve_rising_sun » Mon Jan 15, 2007 8:07 pm
Its hard enough as it is to fit in a Brumby lets not get silly
Steve
Post by Gannon » Tue Jan 16, 2007 4:42 pm
i found that pic on the USMB,... wonder how many hp she puts down?
Post by AndrewT » Tue Jan 16, 2007 4:49 pm
Yer looks American, brake booster and steering wheel on the wrong side.
Also found on USMB :)
daniel
EG33 Brumby
Post by daniel » Fri Jun 29, 2007 8:08 pm
Hi everyone. My little brumby is coming along well, but a little slower than hoped for. dad (steve_rising_sun) still has to wire up ecu out of front cut. come on dad. underside of car is done, brake kit went in great and was worth every cent. thanks gareth. exhaust went in last week, 2 1/4 all the way so should be fairly undetectable to mr policeman. front lights back on after the chop chop to fit engine in. good thing dad had the two 6' shoehorns from last project. box fit ok with a little persuasion. handbrake lever modified for rear. svx dash is in, will be running all guages and stuff from original loom when dad gets around to it. new carpet arrived and seats redone to go back in asap. fuel pump(vl turbo) in and new fuel lines hooked up.
next week roll bars and radiator after that. i suppose a few more months and i could maybe be driving a very personalised brumby!
Jeff
Post by Jeff » Fri Jun 29, 2007 8:30 pm
how haed was it to fit the svx dash?
stamp_licker
Post by stamp_licker » Fri Jun 29, 2007 8:33 pm
Moving along nicely,should get up and boogie.
Building a hardcore postie:D
90brumby
Post by 90brumby » Fri Jun 29, 2007 8:34 pm
im love it would else is there to say
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
daniel
Post by daniel » Sat Jun 30, 2007 6:35 am
not as hard as i thought. a few whacks with the implant device (hammer) to spread the standard brumby instrument housing and a couple of screws and in he went. had to snip a couple of mounting tabs from svx cluster but the fit is very snug and not going anywhere. unfortunately i cracked the clear plastic protective cover, so will have to order another from america.
steve_rising_sun
Post by steve_rising_sun » Sun Jul 01, 2007 4:10 pm
daniel = son of Steve
BRUMBERTY
Post by BRUMBERTY » Mon Jul 02, 2007 10:29 am
Steve = master of understatement
1989 Subaru WonderBrumby II
Jeff
Post by Jeff » Sat Jul 07, 2007 4:12 pm
So Daniel could you post any pics of the svx dash and did you only use the cluster and harness or did you fit the whole dash? Forgive the questions but i am looking at putting a digital awd dash from an L series in my ej20t brumby conversion so any info from your dash conversion would be a help
daniel
Post by daniel » Sat Jul 07, 2007 5:36 pm
I used the brumby orig dashboard and the svx instrument cluster. guys said to use the coup dashboard and go for the digital my cluster, but all the loom fit to the svx cluster....anyway... the cluster fit quite snug into position, i just needed to spread the brumby cluster housing, cover for the top corners as the svx cluster is more square than the brumby hole. the angle of the cliuster is different, brumby bottom heavy but svx top heavy so the plastic retainer that has the wiper and hlight switches has to be cut right back.
i dont know how different the svx is from the digi dash you have, but will send a few snaps next week. going to be a pig to wire up properly though.
car is running, dodged the starter wiring for now and computer runs well, just needs a big tidy up and get the rest done
cheers
daniel
Jeff
Post by Jeff » Sat Jul 07, 2007 6:24 pm
So you used the svx dash loom in the brumby dash
daniel
Post by daniel » Mon Jul 16, 2007 9:10 pm
svx cluster in brumby dash.
just got wired up today and drive in carpark. poor little thing goes like a rocket!
steve_rising_sun
Post by steve_rising_sun » Fri Jul 27, 2007 9:40 am
Hi guys Daniel has it on the road. It takes off well
Steve
