Fortnightly Clutch Adjustment.
There are many many reason why im not running the lib box.... and im far from wanting to have the car off the road for that long and spending that sort of money at this stage. Maybe later down the track.
Yeah im begining to think it is the clutch physcailly fallen apart although after adjusting it works fine... weird.. I could not decifer anything else u said... maybe it is in code or u had too many crownies.
Thanks OS
Dave
Thanks OS
Dave
- Brumby Boy
why does everyone pull the engine to do the clutch on here? i have been brought up to pull the box out, i find it alot easier, well at least with a hoist. though when we did the manual convert in my cousins commo on the floor it wasnt too bad.
RIP 1992 Brumby
RIP 1992 Brumby
errm Coronas this Christmas !
Who made the clutch ? Autoclutch ?
Can you fit a lib flywheel inside the EA bellhousing ?
La Cerveza Mas Fina
La Cerveza Mas Fina
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
Not sure on either OS. I don't belive so with the Lib clutch fitting.
Brumby Boy... if the car had the standard box and engine then i wouldn't pull the engine... actually if it was the stock motor it would only take about an hour to pull the motor and put it back in anyhows.
I have an EJ22 in an ea81 engine bay... gives me about 10mm at best clearance on either side and the front.... i can't even move the box back far enough to slide it off the input shaft. Thats why i remove the motor... turns out much much easier.
Dave
Dave
Dave
Dave
DAMN IT!!!
My fault... thanks Mattims.
Dave
Dave
- Brumby Boy
SuBaRiNo wrote:Brumby Boy... if the car had the standard box and engine then i wouldn't pull the engine... actually if it was the stock motor it would only take about an hour to pull the motor and put it back in anyhows.
Dave
Dave
oh ok i mainly work with newer soobs and with a hoist. i suppose ill learn all the tricks of gear box fitting/removal when i fit my ej22 and 5 speed
RIP 1992 Brumby
RIP 1992 Brumby
- Suby Wan Kenobi
- tim_81coupe
- tim_81coupe
Yeah hatchie is all good now... just need time to tindy up the engine bay a bit and add some of the bash plates and splash guards back on.
Yes it was the fork as i began to expect although it was much more stuffed than i had imagines... i will post pics when i have time.
Also i found that one of my gear box mounts is actually not functioning at all so i will have to give that some attention also.
Dave
Dave
- waggaclint
Yes i did.... but it's not exactly a part that is meant to wear out... or a part that can be purchased easily new. I also looked into getting the old fork strengthened before i put it in but it could not be welded for some reason.
Shit happens.
Dave
Shit happens.
Dave
- waggaclint
I have seen it happen on one other car running the same clutch set up.... if it goes through another one i will have to re think my clutch/box options.
In saying that though i have seen one crack from running the stock clutch.
Dave
Dave
- Suby Wan Kenobi
Dave if its any help, that one I gave you which you are now running was taken from an RX Turbo! Mabey its stronger!!
hehehe (not)
hehehe (not)
EZ30 L series - Monsterwagon
- tim_81coupe
