ej22 clutch and accl cables
TW83
Post by TW83 » Wed Oct 11, 2006 2:59 pm
Hey just wondering how you go about hooking up the clutch and accelerator cables with an ej22 into MY conversion. Ej box by the way.
BRUMBERTY
Post by BRUMBERTY » Wed Oct 11, 2006 3:25 pm
Clutch cable will work just fine, TW you may need to add a washer.
The accelerator cable I used was from an 1991 model teltsar, perfect length and it just needed a trim of the plastic clip to get it to fit the firewall hole.
It even comes with a mounting tab to screw right into the hole in the inlet.
You will se what I meen.
Good luck.
Matt
1989 Subaru WonderBrumby II
TW83
Post by TW83 » Sat Dec 02, 2006 1:16 pm
BRUMBERTY wrote:Clutch cable will work just fine, TW you may need to add a washer.
Good luck.
Matt
Hey where you refering to the ej clutch cable because the my one seems about 15cm too short
Thanks
BaronVonChickenPants
Post by BaronVonChickenPants » Sat Dec 02, 2006 4:02 pm
Try an L series one
MY_STI
Post by MY_STI » Sat Dec 02, 2006 4:12 pm
If the EJ clutch cable can't be made to fit at the pedal end go the L- series cable, you will also have to change the cable mounting bracket on the EJ box to the L series one. no mods, its interchangable.
Currently using a late 80's 929 acc cable, which is probably very simlar to the telstar. Early NA imprezza acc cables are also a nice fit.
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
SuBaRiNo
Post by SuBaRiNo » Mon Dec 04, 2006 7:53 am
I used the Lib EJ22 acc cable.
Dave
TW83
Post by TW83 » Wed Dec 06, 2006 6:35 pm
The telstar acc cable worked pretty good, the one I used was off an 88. Only issue could be that a ball is used to mount the cable to the pedal instead of the standard cylinder shaped metal end. Could wear out?
Just attempted to fit the L series clutch cable. Length -good, fit to pedal- bad! Mounting system is quite different and looks like we will have to modify the pedal box to get it to bolt up. Any other ideas or hints, would prefer to use the L cable as had to buy it from subaru and it cost $90.
TW83
Post by TW83 » Sat Dec 09, 2006 11:14 am
So, have I got the wrong L series cable or have you all modified the pedal box to make it fit ?????
TW83
Post by TW83 » Sun Dec 10, 2006 11:12 pm
Ended up taking the pedal box out. Grinded off the cables bracket, welded six mm steel plate where the bracket was and tapped the steel to bolt the L series cable to. Worked pretty good.
daza
Post by daza » Mon Dec 11, 2006 8:26 am
TW83 wrote:So, have I got the wrong L series cable or have you all modified the pedal box to make it fit ?????
The MY pedal has to be modified to take the L cable.
Daza.
:D
red_rocket
Post by red_rocket » Mon Dec 21, 2009 12:44 am
i have just put an EJ22 motor in my 88 L series and have also noticed that the accelerator cable is short, do i just use an EJ one and will it fit staight up?
L series project
http://www.ausubaru.com/forum/showthread.php?t=14491
Rolling in the 99 Rex though :D
GOD
Post by GOD » Mon Dec 21, 2009 3:17 am
I used one from an early 90s Telstar. Flexible Drive Agency part number BA278. It's a few mm too long, but a cable tie works a treat to pull it tight.
Dane.
Post by El_Freddo » Mon Dec 21, 2009 3:47 pm
I've used the EJ cable - I drilled out the hole in the firewall with a file to fit the EJ cable, then laid it out the way it does in the liberty engine bay. Works a treat and is just long enough for the job as I've not altered the go faster pedal in anyway...
red_rocket
Post by red_rocket » Mon Dec 21, 2009 6:22 pm
thanks guys, very helpful. probably go with the EJ one as i can get one for pretty cheap i think
L series project
