L Series 2" lift - Steering prob
Rod
Post by Rod » Thu Sep 28, 2006 9:59 am
Hi Guys,
Just had my subi lifted 2" and fitted some new 14" rims & slightly wider(195) tyres. I expected my steering to be heavier(bigger tyres) but it seems to have completely lost its self centring & has become very uneven in it's turning force. I had it all wheel aligned and the mechanic is yet to test it but - he reckons it's just from the bigger tyres & is expected.
Just wondering if anyone had a similar prob when they lifted there's?
Any feedback would be much appreciated.
Thanks again
Rod
Suba
Post by Suba » Thu Sep 28, 2006 10:06 am
What sort of lift have you had done.
Mike.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Sep 28, 2006 11:03 am
You sure you havent put the tower tops in the wrong way around?
The long road ahead
Post by Subafury » Thu Sep 28, 2006 8:03 pm
i lifted mine 3" last week with 27s and seems fine, almost normal with allowances for the tyres.
SuBaRiNo
Post by SuBaRiNo » Thu Sep 28, 2006 9:59 pm
yeah i would guess the strut tops are put on wrong some how.
Dave
daza
Post by daza » Fri Sep 29, 2006 8:24 pm
I was once told the change in Caster(from the lift-not adjustable) can make the steering lighter and have less self center, but it shouldn't be too much?
Daza.
:D
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Sep 29, 2006 8:45 pm
With an L series the offset in the tower top block is offsetted to make the strut sit in the same spot it would have if the strut was lowered in the same spot as original. Or they do anyway in an AUSubaru kit.
The long road ahead
