L series clock help (RX turbo)
r00fi
Post by r00fi » Wed Sep 27, 2006 11:10 am
Clock in the middle of my dash has stopped working (86 RX turbo)
Can anyone tell me how to remove the clock? Hopefully it's not a "dash out" problem
Is this a common problem?
BrennyV
Post by BrennyV » Wed Sep 27, 2006 11:49 am
should be able to pop it out. just clips in on the sides from what i remember, and its just a unplug and re plug and ya done ;) make sure you do it slowly tho, sundamage will make it very brittle and easy to brake.
Hunter S. Thompson
subelover
Post by subelover » Wed Sep 27, 2006 1:23 pm
yep just get something soft and gently pry the clock out they just click back in eezy peezy..cheers
stamp_licker
Post by stamp_licker » Wed Sep 27, 2006 2:31 pm
give it he old fonz tap gets mine working again
Building a hardcore postie:D
maudsland
Post by maudsland » Wed Sep 27, 2006 5:39 pm
if all that fails ,,,,, try a big hammer,,,,, if in doubt give it a clout, bigger the doubt bigger the clout
Chris_Rogers
Post by Chris_Rogers » Wed Sep 27, 2006 5:49 pm
it will pop out. if you cannot pop it out drop the glovebox out and give it a push from behind.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
Post by Alex » Wed Sep 27, 2006 8:31 pm
yeh they just pop out....mine crapped itself too, one of the resistors gets extremely hot, and the colours have burnt off, so i dont know what resistance it is!
Post by Subafury » Wed Sep 27, 2006 8:46 pm
check ur fuse too. just a thought- sometimes its the simplest thing.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed Sep 27, 2006 10:52 pm
Sometimes the plug gets jammed on one of the dash supports
The long road ahead
PeeJay
Post by PeeJay » Wed Sep 27, 2006 10:55 pm
After I did the EJ conversion mine keeps loosing time... I'll have to check it out one of these days...
Post by steptoe » Wed Sep 27, 2006 11:14 pm
the clock has the dash coloured plastic surround that comes out with it, the wedge clips are at each side, not top or bottom. Why five wires to run a clock ? 2 are for the light up bits
been thinking of something different to shove in the hole - turbo timer ?
waggaclint
Post by waggaclint » Wed Sep 27, 2006 11:15 pm
PeeJay thats because the car is faster now with a ej in it and the clock cant keep up.....lol
2011 Forester X
r00fi
Post by r00fi » Thu Sep 28, 2006 3:40 pm
How about a Megaview?
http://www.bgsoflex.com/mv/megaview.html
Captain Obvious
Post by Captain Obvious » Thu Sep 28, 2006 6:29 pm
hey for all you guys out there with l's and stuff clock if you have a soldering iron they are esay fix, for some reason son of the solder on the capacitors go dry and the clock display will fade in and out, pull the cold out oull it apart and re solder the joints and it should work again, dit this to a few i had and they worked ever since....
hope that helps
cheers
bryan
Post by steptoe » Fri Sep 29, 2006 9:05 am
out comes the soldering iron and wiring diagram
fredsub
Post by fredsub » Fri Sep 29, 2006 11:00 am
:mad: I have resoldered the wires to it, replaced a resistor, and the thing is still playing up..........must be full of dry joints, last time i broke the clips too:mad:
r00fi
Post by r00fi » Sat Sep 30, 2006 12:34 pm
I haven't removed mine yet, but if there are any electrolytic capacitors on the board, try replacing them too. They are notorious for drying out.
r00fi
Post by r00fi » Fri Feb 09, 2007 11:07 am
Clock fix
This resistor is in the supply (probably for a Zener diode) and gets hot.
Eventually leads to solder failure.
Resoldered and is now perfect....
L series clock.jpg (89.36 KiB) Viewed 10873 times
Post by Alex » Fri Feb 09, 2007 11:19 am
what are the specs of that resistor? mine is fully stuffed!
r00fi
Post by r00fi » Fri Feb 09, 2007 1:01 pm
I have a high res version of the pic but can't read the exact ohm value written on the pcb. It's definately 2 Watt, and has 820J stamped on the resistor (820 ohm???). You could try a 1K 2W or maybe someone has a clock laying around the garage that they read the value from?
