88 WRX Touring Wagon Project
Will post up pics of the brakes in the process of fitting tomorrow (internet connection at home is too slow for imageshack)
Not much clearance between factory WRX 17" rim & rear suspension arm, but it still clears though.
The other advantage of the kit is that it moved the rear wheels inboard about 5mm or so each so I hopefully am not going to need to get the rear guards pumped, though the inner lip will still need to be rolled.
Need to "clearance" the sway bar mounts to miss the handbrake cable, but doesn't look like too much work.
- Chris_Rogers
I'm still working on using the factory L item.
I've got access to another rotten shell which I'm going to tip on its side with the rear suspension & tailshaft still in place.
Going to then massacre the spare L lever I've got.
Basically aiming to run a single cable up the trans tunnel & then split into 2 in the void under the rear seat.
I had a really crazy idea of simply running the Lib cables up the sills & then joint them to the L cables which are gently looped around somehow.
Absolutely no lever mods at all!! But you'd have an exposed joining of the cables. Plus they're not protected up in the trans tunnel.
- Chris_Rogers
- Chris_Rogers
I've had new brake line made up for the rear end to suit the disc brake rear trailing arms.
Also, I've had this brilliant idea with the help of a friend where you use the existing L handbrake & cables, plus the EJ cables
How's this for a handbrake idea
No mods required to the factory lever.
No mods required to the centre console
No extra holes to be drilled all the way through the floor.
Extra mounts for the cables are required though.
There is no bindage with this setup (ie the cables aren't on too tight a bend)
Now to figure out how to join the 2 cables together....
- Chris_Rogers
- Chris_Rogers
I'm going to take 2 sample cables to a cable doctor tomorrow.
I'll ask the question about making up one.
I'm a little dubious about reproducing the end where it fits into the EJ backing plates...
I really would've liked to have used a leather Lib RS turbo lever, but it just doesn't match the console (for a Vortex on the other hand)
- subarursliberty
meh, I needed to take some frustration out on something anyway.
And I couldn't bash it anymore as it didn't have a straight panel left.
Was $17 just for a bare shell, or rolling, or what? I've got a lot of other metal to go with it.
Beside $17 is at least 3 beers at the pub.
Went to the cable doctor today.
It took a while to explain to him that I only wanted the cable inners joined, not both cables together. Which turns out that while its doable, its most likely not legal or engineerable.
New cable inner is $47ea, or a complete new assembly is $80ea. So that's $160.
Still going to think about a floating metal bracket that fits onto each cable end though. Just going to have to seal it in.
- Chris_Rogers
subabits
- subarursliberty
fark in perth u can grab at least 40bucks for a shell? they are real tight over there
Hunter S. Thompson
Hunter S. Thompson
Ok, been a while, mainly because the project has had nothing done to it.
Handbrake cables have been made up but not fitted yet (first week in new year job).
I've basically given up on putting the EJ motor in. I've had too much hassle trying to get all the coolers in the front, plus fans.
I'm going to try a different tack by installing a H6 motor instead. I will still have radiator to engine clearance issues, but without the need to fit an intercooler radiator in with the A/C, I could fit the fans in between the rad & A/C.
Plus I'm in the need for a tow car for the rally car project I'm trying to do (too many projects at the moment...
) & the 3.0L 6 cylinder would be a better bet for this.
So, if anyone is chasing an early WRX engine with ECU & wiring, plus a Lib water-air intercooler...
Also, if you know where I can source an early H6 motor & wiring (prob half cut better)...?
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
