Bantum's '05 Forester ...
Moderator: Bantum
Headlights ...
Post by Bantum » Sun Jan 11, 2026 2:57 am
Well its been a busy few weeks after Forrie suffered some hail damage - ( end of Nov 2025 )
So decided to tackle fixing a few issues along the way ...
Pulled apart the light body & cleaned up :
Some new hardware to go in :
Repairs / repaint done to chrome bits :
3D print parts for LED Strip :
Testing :
& spent few hours polishing the f*ck out of the lens :
more to come ...
Hailed ...
Post by Bantum » Sun Jan 11, 2026 3:20 am
Also did a bit of dent pulling to see if this gadget worked :
Still need to do more :
Plan is to wrap it after I've done repairs :
Image to come ...
Also added a drain ( from plumbing dept @ Bunnings ) to back of headlight :
Not sure if that will solve issue of leaky seal, will see ...
Mini spots ...
Post by Bantum » Sun Jan 11, 2026 3:32 am
Found a LED light that actually fits between the grill slats :
So set about making some brakets to hold them in place :
And a WIFI control unit to run it :
Comming together nicely :
Awaitng a few more bits to complete the asembly & will update when I have it in hand ...
Cheers, Bantum ...
Re: Bantum's '05 Forester ...
Post by El_Freddo » Sun Jan 11, 2026 7:37 pm
Neat work as always Bantum.
I’m keen to see the wrap you go with!
Subyroo
Post by Subyroo » Mon Jan 12, 2026 9:57 pm
G'day Bantum, what is your verdict on the dent puller?
Dents ...
Post by Bantum » Sun Jan 18, 2026 5:30 am
The Dent puller has worked so far, but is a bit messy / tricky to apply with hot glue sticking to everything & if your'e not carefull will burn fingers ... :oops: + if the paint is not well laid down it will also lift, have a bit more work to do & will post some after shots when I get round to it ... :biggrin:
Subyroo
Re: Dents ...
Post by Subyroo » Sun Jan 18, 2026 11:30 am
Did not want to hear about the paint lifting, looks like I will have to get the paintless dent removal guy to do the job. I don't have the confidence in my ability if it's that easy to damage the paint work.
Thanks for your feedback, it is appreciated.
Post by El_Freddo » Sun Jan 18, 2026 3:46 pm
How do you go about removing the glue after you complete your dent pulling? Hopefully it’s an easy task removing that glue.
Looking forward to some before and after pics!
Re: Hot Glue Removal ...
Post by Bantum » Sun Feb 01, 2026 4:16 am
From internets :
"To remove hot glue from car paint, gently heat the glue with a heat gun to soften it, then carefully scrape it off with a plastic scraper or credit card, loosening it gradually; follow up by cleaning the residue with isopropyl alcohol or white vinegar on a microfiber cloth and finish with a wash and wax."
Have yet to try it - so will get back to you on results ...
Ciao, Bantum ...
Post by Bantum » Wed Mar 25, 2026 4:11 am
Added to the collection of parts :
Need to find suitable tyres next - Got any recomendations ?
Ciao, Bantum
Return to “Bantum’s Works”
