Gorilla Super Glue Gel is specially formulated to absorb impacts, drops, and shocks as it contains tiny rubber particles that increase its strength and impact resistance. Works well for bonding rubber as well as plastic, metal, wood, ceramic, leather, paper and other materials.
Ruby Scoo’s epic build, ten years and counting...
Moderator: El_Freddo
Re: Ruby Scoo’s epic build, ten years and counting...
Bennie re the cracked rubber, try Gorilla Glue on the crack.
- Silverbullet
Yay Ruby scoo is back!
Good to see she is still getting some love. Is that cracked rubber piece a replaceable part? Or can you "repair" it with a sealant or silicone of some sort?
I've been having water leakage issues in my wagon too, traced it to the windscreen rubber. Have had wet carpet in the drivers foot well a few times in the last few weeks before I tracked it down
Got my hands on some mastic sealer to squirt under the rubber like the manual says to do, never got around to it before. We've been having the most rain since 5 years in the past 4 weeks it's been incredible.
You might have said before but, is Ruby scoo going to see any more camping/4wd'ing trips in the future?
I know you've upgraded to something a bit more stout in recent times. Would love to join you on a trip some time now my wagon is all but ready
Hey Suparoo, thanks for the suggestion, dunno if it’ll work on the section required. It’s where the window winds up to when in the fully up position, this rubber bit covers over the top of the window when up. So it’s a one piece left, right and over. It could be more plastic than rubber, dunno really.
Silverbullet, yes it’s replaceable. I have to remove the whole corner triangle piece and possibly the front window runner, it’s been a while since I swapped them out! I’ll have to see what I have stashed away in good condition and when I can swap it.
And yes, Ruby Scoo see more offroad action, just without the whole family unless we take two vehicles (I doubt Mrs El_Freddo will want to be the sole driver offroad. It’s hard enough to get her in the drivers seat out bush at times!).
I’m hoping that once these mods are done that I finally move into the maintaining phase where I can start to tidy up a few areas that need attention. And then just drive her lots! 600,000km? Yes pls!!
This is what you are talking about ... Y/N?El_Freddo wrote: ↑Sun Aug 01, 2021 9:45 amHey Suparoo, thanks for the suggestion, dunno if it’ll work on the section required. It’s where the window winds up to when in the fully up position, this rubber bit covers over the top of the window when up. So it’s a one piece left, right and over. It could be more plastic than rubber, dunno really.
No harm in trying the Gorilla glue or even Superglue, might save you having to replace it altogether.
I Superglued a part of my Forester gusset, but it was so long ago (+10yrs) I have forgotten exactly where it was on the gusset. More than likely the same place as it appears to be a common problem, along with this one about wind noise...
Good luck Bennie.
That’s the spot Subyroo! Except that mine is cracked over the top just to the inside. Seems to be enough to let the water leak in. Hence why I thought some tape might fix it.
I don’t know if my triangle piece is fitted properly or not as the window wants to come up a bit further than the triangle really wants it to. Small things and was never an issue until last year
Now to find out the last time I did a cam belt on it as I can still read the words on the one that’s in it now, not like just an outline left, but all the words are easily found, just browny in colour...
Last post AUG21. OCT21-ish Ruby a Scoo was loaded up with all of her project parts and trailered to M&D’s to live under a tarp as we worked out where we’d be moving to (landlord wanted vacant possession for sale).
Fast forward almost three and a half years of living under said tarp and the tarp is pretty knackered. Ruby Scoo’s paint didn’t fair too well but overall things look better than I was expecting.
Best bit was the start up. Fresh battery, jerrycan of new fuel, gave her a kick with the key (after turning the engine over by hand a tiny bit) and she fired up no worries. That was last night in the space of about 15 minutes. Lost daylight after that. She drove out of the paddock to the driveway on one almost completely flat tyre.
This morning tyres were pumped up, windscreen washed, fired up and let to reach thermo fan operation temp. Then we went for a drive! Brakes are woeful due to surface rust, but something is there working so that was good. Everything except the taco and cruise control work so I’m pretty stoked!
Got an exhaust leak, some small vibrations (not worried about those) and a head unit that only wants to work when it wants to but won’t play music…
Now to drive her the hour and a half home. She’ll be right!
And right she was. Flawless drive, no issues on the drive.
Got some things to look into which was expected.
Sorted the stez out and listens to some tunes.
Pretty stoked!
MERRY CHRISTMAS!
Pretty stoked!
MERRY CHRISTMAS!
- Silverbullet
Heck yeah!
So we'll see her out on the tracks again some time soon?
Merry belated Christmas and happy new year.
Install immobilisers to your pride and joy(s)!! Or at the very least a hidden kill switch!
Ruby Scoo was the victim of an attempted theft last night. Police report made - as did another neighbour who had their car broken into a rummaged through. I’m now waiting to see what the local police do before I touch anything.
Two things worked in my favour - firstly, Ruby Sports a discreet immobiliser. No flashy light to say I’m immobilised! The best bit is, and this is the second thing that worked in my favour, Ruby Scoo borrowed Redback Brumby’s battery to drive home from storage at M&D’s. So there was no battery to begin with.
The would be thief was “very respectful” as they used a screw driver to remove the cowling from the steering column to access and remove the ignition switch from the back of the key barrel. After nothing happened when they used the ignition switch I think they flicked every switch on the dashboard hoping one was a kill switch - only to come up with nothing. They popped the bonnet to assumably look for a battery switch/disconnect only to find no battery - at which point I suspect the endeavour was abandoned and they moved on, leaving the driver’s door open - the only thing that alerted me to someone tampering with my vehicle.
Apparently CDs or my 20yo headunit wasn’t good enough for them either - both were left with the CD having been removed from the glovebox and left on the passenger seat.
This is the second time cars were targeted for theft or their valuables stored in the vehicles. Last year a neighbour had their VE Commo stolen by using the car keys the thieves got from breaking into the house while they slept. That was taken from their driveway.
Ruby Scoo was parked on the street. Basil, the Gen3 RX Liberty was parked beside Ruby Scoo and seems untouched. I would’ve thought Basil was the better pick of the two vehicles - less conspicuous of the two and a pot load faster! Also happens to be full of fuel too…
Get those immobilisers and kill switches sorted! Or if you’re lucky enough to have a shed get them locked up in there or off the street at least - still no guarantee they won’t be touched, just less likely from opportunistic f’wits.
- Bantum
Mis-adventures of the fortunate, sounds more like ... good to see Ruby back on the road.
Sorry to hear of the misfortune - any damgages ? I had similar experience with MY wagon - was constantly getting a srewdriver in the locks & smashed windows, with thives tyring thier luck ( already had a silent alarm fitted fortunately ) but still made a mess ... :/
Made the one for my Brumby way 'louder' with visable flashing lights / sirens etc, which seems to have kept them at bay ... Would say that stock they are dead easy to get into ( without breaking shit ) so its obvoius that hoons / joyriders are just out looking to take the easist one to get into. Seen heaps of reports of a Brumby being taken for a ride & dumped ( mostly found crashed afterwards ) So definitely would recomend at minimum a hidden kill switch & upgrade to a full alarm when your budget permits.
P.S. Another trick is to remove the rotor when your not using it- easy to do & will take 'em ages to work why it won't go ...
( Just make sure you put it somewhere safe - preferably with the keys )
Ciao, Bantum ...
Ciao, Bantum ...
Couple of things Bantum - how do I remove the dizzy rotor?
And Ruby Scoo is already fitted with an immobiliser
Last night I went to move Ruby Scoo to the backyard only to find that after putting some borrowed bits back on her and throwing a battery in that the would be thieves f*@ked my ignition barrel. Bit pissed about it. Pulled out a 5mm tip of a pair of scissors but there’s still something further down that I can’t get out. Otherwise I’d be able to get the key in and it should work if the little finger thingys aren’t stuffed (most likely are).
Got a mate keeping an eye out for a replacement unit for me. I might have one at M&D’s. No rush really.
Next goal for the weekend: empty the wagon of all the project parts currently stored within for her upgrade projects.
- Silverbullet
That sounds truly awful to have your baby broken-into and mistreated like that
Some of my most horrible nightmares involve my car being vandalized
And even L series parts are getting harder to find these days, makes replacing damaged items even more frustrating.
I have a query for you Bennie regarding Ruby Scoo's gearbox. IIRC you have an OBX front LSD right? But I can't recall if you still have an L series 5spd or if you went to EJ 5spd...in any case would you know if EJ inner CV cups can be used on a standard L series front CV shaft? It would need the spline on the axle part to match up where the CV inner race slides on. I don't have a spare L series and EJ front axles here to play with and find out for myself.
Thinking long and hard about a front LSD for my new box. Subarino Dave has a Quaife in Hatchie, I might be convinced to cough up the coin but I want to know if I can still use my current L series front axles without the rigamarole of doing the whole 5 stud conversion. Quaife or OBX, they have EJ output stubs. Seen a video online of a new OBX unit in pieces and the quality of the machining/finishing scares me a bit
Not to mention I can't even find anywhere online that would sell one.
- Bantum
Ha - Didn't I say it was for your older EA81 - which has one, guessing your's dosen't ...
You could get creative & make up a fake one to confuse the hell out of a would be burglar ...
Good to hear, trouble is they only work when powered up - keep at it ...
Cheers, Bantum ...
Yeah that Quaife would be awesome! I went the OBX because it was cheap. After having it fitted I found out about a $US30-odd dollar kit that “fixes” all of the cheap work put into them. Apparently once cleaned up and had this kit out through them they’re as good as the quaife. But mine doesn’tSilverbullet wrote: ↑Sat Feb 08, 2025 10:46 amI have a query for you Bennie regarding Ruby Scoo's gearbox. IIRC you have an OBX front LSD right? But I can't recall if you still have an L series 5spd or if you went to EJ 5spd...in any case would you know if EJ inner CV cups can be used on a standard L series front CV shaft? It would need the spline on the axle part to match up where the CV inner race slides on. I don't have a spare L series and EJ front axles here to play with and find out for myself.
Thinking long and hard about a front LSD for my new box. Subarino Dave has a Quaife in Hatchie, I might be convinced to cough up the coin but I want to know if I can still use my current L series front axles without the rigamarole of doing the whole 5 stud conversion. Quaife or OBX, they have EJ output stubs. Seen a video online of a new OBX unit in pieces and the quality of the machining/finishing scares me a bitNot to mention I can't even find anywhere online that would sell one.
One day it might.
I do recommend a front LSD. My gearbox is a complete hybrid and uses the 25 spline EJ output stubs. Not an issue though as the L series had two models that used the same stub axles and the CV joints are available off the shelf! The MPFI manual touring wagon and the MPFI RX turbo both ran a 25 spline diff stub axle. I’ve got a pair in Ruby Scoo and they work perfect.
As for my gearbox specs: Phase 2 EJ front cases with phase 2 drive gears etc, L series locking centre diff and matching rear housing, modified locking centre diff pinion shaft for 4.111:1 diff ratio and as an extra, oil “feeders” (dribblers really) over/above the low range gearset for hill climbing lubrication and cooling. Mint!
Hahaha… no you didn’t say for my EA81! And yes, the brumby is still EA81 powered for now! Because you posted in Ruby Scoo’s thread I just assumed you were talking about Ruby Scoo!
I used to do the whole rotor removal - especially when parked in places I wasn’t happy about. Actually I’d still do it if I felt that way. But I’m always cautious not to lose the rotor button and screw myself over! That’s not happened and hopefully it won’t be an issue.
In other news, Ruby Scoo now sits basically empty. I took out a split closed deck EJ20G block originally from the RS, the kit for my 5 stud conversion, the torq locked rear diff that’s yet to be fitted, and some brumby bits I was looking for!
Next is to remove the steering column to get the ignition barrel sorted so I can move her off the street.
Ruby Scoo surprises me again - but in a different way than how she used to when offroad.
I pulled the steering column out today to pull the ignition barrel off hoping for a locksmith to fix it and retain my original key.
After knocking the barrel off the steering column, I tapped it on a cement paver and the metal piece stuck in it came out! I tried my key in it and it seems to prefer the keys that aren’t worn out like the original one is. It does need a little jiggle to get it to work but it works!
Back in went the steering column after refitting the ignition barrel. Then I had to sort out my maze of wiring I have stashed under there! This included remounting the ECU to the steering column. Now my steering wheel is a bit cock-eyed but I’ll sort that out.
She’s living in the yard now. This will allow me to tinker away as I see fit. And since she’s emptied of everything I can start cleaning her out and giving here a decent wash etc. Nothing will make her paint look any good unless it’s a full respray now. She’s suffered badly in that department. Main thing is she’s off the street in apparent safety. Fire or a hail storm are my only big concerns now.
- Silverbullet
Hey Bennie, time for more questionsEl_Freddo wrote: ↑Sun Feb 09, 2025 7:36 pmI do recommend a front LSD. My gearbox is a complete hybrid and uses the 25 spline EJ output stubs. Not an issue though as the L series had two models that used the same stub axles and the CV joints are available off the shelf! The MPFI manual touring wagon and the MPFI RX turbo both ran a 25 spline diff stub axle. I’ve got a pair in Ruby Scoo and they work perfect.
I am pushed towards following the same path as you, since the Quaife LSD was only available with 25 spline output. Would you know of an easy source of these 25 spline L series inner CV joints? New would be preferred, the type with 6 ball bearings. If they can fit onto my current front L series shafts (23 spline inner joints) I would be very happy.
Timing is not bad too since I think my front drive shafts have pretty well reached their used by date, inner and outer. There were some galling/pock marks on the bearing balls of one inner joint last time I changed a boot.
Cheers!
Anything EJ that fits on the end of your MY shaft will net you an inner CV cup with 25 spline count.
Getting the spline for the ball race and cage correct for your shafts is the painful bit.
If there’s a shaft builder joint near you it could be worth the shot talking to them about what you need.
Or inquire with Quaife about custom 23 spline output shafts - this would solve many headaches down the track.
- Silverbullet
Thanks Bennie, I was leaning towards something like that BUT! I don't have any spare front L series shafts or EJ shafts to play with or mix n match. If I took the ones out of my car to play with then that would make it non-drivable after I change the inner CV. Maybe not so bad if I was doing the gearbox swap at my house but I'm not
The 25 spline Quaife LSD is already in the hands of Subiesnax (gearbox man) So begins the saga;
I made the call to buy 2 new aftermarket shafts for L series RX Turbo...
Rang my local CV driveshaft shop, he said they don't sell complete GSP shafts for Subaru any more due to quality concerns in the past...
So I rang Bursons, the American GSP part number didn't come up in their system. No part numbers available on the Aussie GSP website...
Found them on the Supercheap website, CVS.927B special order for $277 each (!) ($49.95 on Rockauto, only 1 left
I gave in and bought 2 x TRAKMOTIVE SB8005 from Rock auto $95.63 ea plus $100 post
I figure even if they're crap at least I can drive the car while I get my good ones rebuilt to 25 spline inner at the local shop.
These should work if the spec sheet is trustworthy.
It won’t be a fun exercise that’s for sure.
This could be where U pullit becomes your friend for sourcing the inner cups and matching races. At least you’ll be able to pull them apart and count the splines before buying them.
I hope they work out for you. If you can work out the diff spline swap it would solve you many headaches including future ones if you need new front shafts.
So here we are, a good year later and I’m finally getting stuff done - namely due to Subinats coming up in October.
I got her fired up after a jump start with a dodgy battery, pumped up some tyres to road pressure and took her out for a quick spin. Gave her a bit of a flogging (as much as you can with one of these) and she took it in her stride as usual.
After that I assessed the exhaust situation - a dodgy joint after the cat that was a patch job when M&D were borrowing her after the gen1 Y pipe fell apart somewhere on the Hume several years ago. Sounded a bit Honda spec and I didn’t like it. So I got a set of these and wrapped them:
While everything was cooling down, I took the old crusty roof rack off that was used when 4wdn - awesome for that, but not the current look I’m after. I put the original rhibo roof bars that came with Ruby Scoo that she used to rock for a very long time before the full roof rack came about to help accommodate the family.
I managed to get the UELs fitted after dinner and too her for a quick run. She’s got her old rhythm and beat back. Stoked!
I reckon I’ll get a new battery and a jerry can of fuel then start dailying my driving her - and do some cleaning. Inside, out and under the engine bay are terrible. I’m not proud, but she’s still here which is the main thing.
And she’ll get us to Subinats this year - bit of a big one from what I can gather - The legendary Hatchie and Settlement Creek Racing’s desert racing Brumby will be there. I’m hoping Lucky Phil can make it again. I believe the dark blue roll racing brumby will be there as will Tony with his show pony (non-offensive use!) EJ turbo converted brumby with the jump seats in the back.
Then there will be Ruby Scoo, “pre-rat rod”…
Monday night after work - picked up a new battery and forgot to take a jerry can with me. Thought I’d just pop into our local servo (where fuel is usually 20c/L dearer than in benders). Nope. Ran out of fuel backing her out of the driveway.
Got a jerry can sorted, $43 later it was full and in Ruby Scoo.
Tuesday, drove to work no worries. Grabbed some duct tape and new wiper blades as the old ones were basically Bluetooth spec. Filled up with fuel, was keen to see the gauge shot for the “F” mark - it crashed well below the E mark before bouncing back up to the F mark. Next intersection it crashed again before sorting itself out.
Wednesday I grabbed a new stop light globe as one wasn’t working. Fitted that in the carpark because safety.
Thursday, used the wipers, they were on super slow mo and nothing changed with the settings. Tried them out earlier today and they’re working like normal again.
Fuel gauge seemingly normal operation - its moving south at an expected rate.
Friday, “rest day” as I needed to use the brumby.
Saturday (today as at time of writing), I took her for a quick spin. When backing out of a mate’s driveway then moving forward it was like I was half in first gear. Weird. Checked the low range lever, all good. Took off again and was in low range. Bit confused about that as the low range selector was in the high range position.
At home I found out my selector rod on the gearbox lost its retainer pin/bolt setup.
All in all, I’m pretty happy with how well she took to doing almost 100km a day without any major issue. She’s a handful to drive from what I remember - got a bit of a touchy throttle when driving gently and the missing bush above the rear diff doesn’t help.
Which reminds me, I should replace that…
