Valve clearance EJ20 DOHC
gary2009
Post by gary2009 » Thu Apr 01, 2021 11:39 pm
I’ve just serviced my heads and the valve clearances are inlet all valves 0.06 exhaust 0.13 is this ok or are the exhaust valve gaps to wide and how do I reduce it as I can’t find small enough shims.
Re: Valve clearance EJ20 DOHC
Post by El_Freddo » Fri Apr 02, 2021 9:06 pm
G’day Gary!
Which EJ20G do you have (year) and what model vehicle did it/is it from?
These two bits of info are important as there were three or four different valve train setups for the EJ20G designation!!
gary2009
Post by gary2009 » Sat Apr 03, 2021 12:17 pm
It’s a GE7 2008 EJ204LP1MB got the valves to passenger side inlet 0.06 all the same and exhaust are out front are 0.10 ,0.14 back are 0.14 and 0.14 the driver side is inlet front 0.07 , 0.07 back 0.07 ,0.06 exhaust is front 0.10 0.11 and back is 0.10 and 0.10 that was me swapping buckets around I can’t get small enough shims all I did was reseat valves and numbered everything as I pulled it down I don’t understand why the clearance has increased they should of reduced. It all started when the timing belt tensioner bolt snapped had to replace two inlet valves when I put it back together I had a bad miss so I replaced the coil packs now I need to change the plugs hopefully will get rid of the miss.
Regards Gary2009
Post by El_Freddo » Sat Apr 03, 2021 5:27 pm
Thanks for the update Gary, dunno why I said EJ20G, you never mentioned that code!
I agree that those gaps should’ve closed up after a reseat job - but if new valves were used that throws things out again and will effect the valve lash.
Can you get new shins from Subaru? I’m guessing you don’t want to wait though. Partsouq are good for genuine items. I use parts from them for the Subarus and our Pajeros in the family. You do have to wait for those parts to rock up though, usually 7 days from order to delivery.
gary2009
Post by gary2009 » Sat Apr 03, 2021 9:26 pm
When I got the new valves they were ground to the size of my old one by a engine reconditioning ferm because they are close to each othe I’ve set them to exhaust each cylinder to 0.10 and 0.14 so all cylinders are the same on the inlet all are 0.06 in the book it says inlet are between 0.06 and 0.08 so with in spec and exhaust is 0.08 and 0.10 which is out of spec but when you read on outer exhaust valve is 0.08 to 0.10 and the middle to are 0.11 to 0.13 so I’ve set it that way you can hear a little ticking but it’s not loud that’s for your help.
Subyroo
Post by Subyroo » Sun Apr 04, 2021 9:28 am
Gary could also try sending a PM to the FROG (Andrew). Hopefully he is still working for the Subaru Dealership.
gary2009
Post by gary2009 » Sun Apr 04, 2021 10:14 pm
My buckets are the solid ones would need to buy new buckets and they are $700.00 a set bit out of my price range being on a pension and fighting leukaemia I have very limited funds due to my radiation treatment I have very limited funds available at this time thanks for your help anyway.
Regards Gary2009
Post by El_Freddo » Sun Apr 04, 2021 10:57 pm
Ah solid shims, ouch!
Sorry to hear about your leukaemia, hopefully you’re finding your treatment beneficial with you on the recovery path to full health sooner rather than later.
Hats off to you Gary, firstly for taking on this repair (many would bin the engine and put another one in!) and secondly, doing it while taking on leukaemia!
All the best with your recovery and hopefully your Subaru will be back in action before long too!
Subyroo
Post by Subyroo » Mon Apr 05, 2021 12:44 pm
gary2009
Post by gary2009 » Wed Apr 07, 2021 12:01 am
Ended up take buckets out and using a dermal and sanded the inside of the buckets down to spec all inlets 600 thou and exhaust all 800 thou except two which were all ready at 10 thou started no miss hoping she won’t give me anymore problems had second round of radiation treatment today first one did nothing .
Thanks Gary2009
Post by El_Freddo » Sat Apr 10, 2021 2:53 pm
Good stuff on the dremel work! Keep replacing the cam belt, tensioner and idlers within the service intervals or earlier ;)
All the best with the next round of treatment!
gary2009
Post by gary2009 » Sun May 09, 2021 1:21 pm
Can someone tell me which is correct on valve clearances I’ve been told that on a EJ204 non turbo 2L motor it’s inlet 0.006mm up to 0.08mm and exhaust is 0.08mm to 0.010mm but the service manual says inlet is 0.19mm and exhaust is 0.35mm which are correct.
Regards gary2009
