Okay I am getting ready to put this box in - but I just want to check its operating right!
Diff Lock lever off -: Turn input shaft - both front drive shafts and tailshaft turns. If I hold the tailshaft - input and front shafts can turn. Thats normal (I believe?)
Diff Lock Lever on -: If I hold the tailshaft - I cannot turn the input shaft. But it all moves if I just turn the input shaft alone.
That is all a-okay isnt it?
How should a Full Time L Series box operate out of the car?
That sounds perfect.
With the diff lock off...holding the tailshaft should really make the input shaft a little more difficult to turn - otherwise that would indicate a worn out centre diff. But most likely it will tighten up with some driving anyway.
EZ30 L series - Monsterwagon
