adjustable strut mounts for L SERIES
- waggaclint
has any one got these or seen em..
Evolution strut-mount adjustable part number 44603 by nolathane..
there new..
http://www.redranger.com.au/proc_selection.php
there new..
2011 Forester X
First time I have seen an L-series offering, KMAC dont do them because there is very little room in the towers for the spring to move around so the actual adjustment you can get with standard springs is minimal before they hit the tower sides - combine this with the fact it is the same listed part as later model Subarus and i am a little dubious...
Unless you are running modified suspention with smaller diameter springs (ie coilovers such as Bilstein's) they wont help much I fear.
85 Leone RX EJ20T Rally Car - plus spare rolling shell
91 Facelift 2.2 GX 4WD Legacy - SOLD
96 RSB Legacy
96 RSB Legacy
The Nolathane strut tops are not available to buy yet but I am taking orders for them.
I will have a trial set in the next few days, I let you all know how they go. There will be some caster adjustment on the 'L' series, but more camber adjustment.
The Nolathane design is totally different to the KMAC or Tein.
Any questions on them feel free to call me 0438 887 746 or email me [email protected]
http://www.subiparts.com.au
0438 887 746
0438 887 746
- waggaclint
Justin,
I have tried a couple of times to contact you and buy some nolathane, but your email server says your mailbox is full and there was no answer from you after left message on your mobile. Can you PM me if you read this to confirm message is getting through? Anyone else having the same trouble?
thanks
thanks
- Suby Wan Kenobi
- Chris_Rogers
- waggaclint
try http://whiteline.com.au/ part numbers for sway bars are
bsf50 for the front.
bsr50 for the rear.
bsr50 for the rear.
2011 Forester X
t303 yes I am having the same problem.
I am keen to purchase a complete bush kit for an L series but can't raise any kind of response from Blackbox...
EZ30 L series - Monsterwagon
Sorry guys! I have had a lot of trouble with my web site hosting company & email.
Please email me at [email protected]
& I will get back to you with in 24Hrs.
0438 887 746
0438 887 746
- Chris_Rogers
I'll give it a click. did they say it would bolt in the existing spots using OEM points. had a kmac one in my sedan and that didn't bolt in.waggaclint wrote:try http://whiteline.com.au/ part numbers for sway bars are
bsr50 for the rear.
- Chris_Rogers
ok front is heavier. rear is std size in my case. I'll have to ring them - ta!waggaclint wrote:try http://whiteline.com.au/ part numbers for sway bars are
bsr50 for the rear.
just a softly nudge:rolleyes: wonder hows this going?Xtreme_RX wrote:The Nolathane strut tops are not available to buy yet but I am taking orders for them.
- waggaclint
- waggaclint
I am still waiting for my demo set..... End of this month I should have them.
Steering rack bushes I certainly have - $20 + P&H. That’s for the pair.
0438 887 746
0438 887 746
- waggaclint
Part number :- 41099.
0438 887 746
0438 887 746
- waggaclint
- Suby Wan Kenobi
