Door glass troubles
Door glass troubles
Hey guys, trying to get the glass out of my door on my Vortex, is there any way of getting it to go down when the electric motor won't work? Having trouble getting at the last two bolts and it says to lower the window until you can see te bolts holding the regulator to the glass holder through the service hole. I can't get the window down because the motor is gone which is why I'm doing all this is the first place.
Canny
Canny
- Bantum
Troubles ...
There are few things you could try :
Cheers, Bantum ...
- Could 'assist' the window by pushing it down ( or lean heavily on it ) @ same time the switch is turned on ... ( Assuming the power is still connected ) Note : Don't put any sideways pressure on it or you will break it ...
- Can you get to the motor ? spray it & winder mechanism with some WD40 see if that frees it up ...
- If all that fails, locate the bolts & drill suitable holes ...
Cheers, Bantum ...
you can power up the wires, one is light blue, the other pink. Switch around between pos and neg gives up or down. Watch any appendages that may get in the way of mechanism.
"bout time you contributed more than questions and thankyous - a picture guide to removing door trim, etc complete with instructions, tips, do's and do nots
I was fiddlin' with my spare door and bypassed all the switches n crap - went direct to the wires from window winder motor and got better function one way than the other.
These motors spin both ways, wonder if they can perform better one direction than the other as they wear and age ? Thinking back to manual winders and their need for renewed nylon giudes and a grease up - wonder if the 1980's grease n stuff has depleted and needs renewal of guides n grease ??. My left window is fast down, slow up. Yet to be investigated
