Largest Wheel/Tyre Combo for a '98 Liberty?
Hi all. What's the largest wheel/tyre combo for a '98 AWD Liberty?
Max outer rolling diameter for lifted (even 6" body lift) is 29". They slightly scrub on the control arm mount and you can't really do anything to prevent it.
EZ30 L series - Monsterwagon
I think your talking rim size if so what ever your tyre height diameter is as long as that is the same you could 15" 16" 17" for sure
Here is a tyre calculator you could have a play with
http://www.1010tires.com/Tools/Tire-Size-Calculator
Jan
Jan
