![Image](http://i189.photobucket.com/albums/z146/1992Roo/Subaru%20Safariwagon/2014_0708AF.jpg)
![Image](http://i189.photobucket.com/albums/z146/1992Roo/Subaru%20Safariwagon/2014_0708AE.jpg)
![Image](http://i189.photobucket.com/albums/z146/1992Roo/Subaru%20Safariwagon/2014_0708AG.jpg)
![Image](http://i189.photobucket.com/albums/z146/1992Roo/Subaru%20Safariwagon/2014_0708AI.jpg)
Moderator: El_Freddo
Problem here is that I need two uni joints! And if I use two of the MY units it's too long! And I'll have two PS units that are then incompleteNachaLuva wrote:Another is to remove 2 of the bolts on the MY rubber uni (#6) and insert a suitable length alloy spacer with HT bolts. This would be a pretty big spacer though, so the first option would be better.
It's broached, not machined. Apparently this is when the shaft is pushed through a die. I've got the contact of a a guy that *might* be able to make up a splined shaft that I'm after. I need a solution before I can get on to this but it's certainly something I want to pursue as it could open up loads of things for others.Silverbullet wrote:Extending the splines not such an easy job, they are a machined item with a specific profile and pitch a bit like a gear...a fair bit of work for a machine shop to set it up right would cost a fair bit.
Not rebuildable, but I've found a mob in town that can replace them with a holden rodeo unit. They've got a machine to press them out and press the new one in. $80 a unit.Silverbullet wrote:I suppose the uni's aren't rebuild-able?
Dunno if a workshop will do it. But for the interim I'm going to DIY it. And here's the reason why I'm comfortable with this: I need about 10mm extra on the spline for me to be satisfied with the shaft length. In theory on the shed floor I could get away with just that splined length but I'm not comfortable using it this way.NachaLuva wrote:One option is to find a workshop that can extend the splines on the shaft in the second pic.
And it works a treat! Horn anytime I want nowtambox wrote:He used something that may be out of your vocabulary NachaLuva, a 22 bullet shell
I'm not sure that I detailed that bit. My original plan was to use a cable from the liberty but it was too long and trying to adapt it to the L series low range lever seemed impossible (nah, just cbf'd!).FujiFan wrote:Hey Bennie, maybe I've missed a post or several but howd you go with the Hi/Lo range selector on your super duper gearbox? I'm assuming you used the cable from a Lib/Imp setup.
Well, I might have the time and opportunity to do something about this crude rod setup I'm currently running due to this:El_Freddo wrote:I'm not sure that I detailed that bit. My original plan was to use a cable from the liberty but it was too long and trying to adapt it to the L series low range lever seemed impossible (nah, just cbf'd!).
What I ended up using was a solid rod that joined to the end of the stock lever. It's crude and I've been meaning to do something about it as it involves a piece of right angle iron with a tab welded to the low range selector fork end for it to attach to. In the middle is a bolt to the stock rod up to the selector lever. And to stop it all bending is a cable tie on the over lap of the RHS with the rod.
Crude but effective. I might get around to doing something about that one day.
I forgot to mention these in my above post, sorry!Venom wrote:So Bennie how was the cooling with thermos all going the right direction? Would be nice if you didn't have to pull up and lift the bonnet for a cool off. Funny how many of us stuck a hand behind your radiator to check air flow? I know I did a few times.
The one on the bottom of the bell housing or the one on top of the gearbox? Both are there. I'm confused...Venom wrote:Do you have the inspection plate fitted to your gearbox?
I'm glad I got home safe too! It was a huge trip to be done in such a short amount of time!! It was basically like driving to Adelaide and back again within 24 hours... Glad the VT broke a few weeks ago - the plastic heater tab let go in the drive way. Got lucky on that one I reckon!NachaLuva wrote:Yeah very glad you got yourself & the car home safe.
I wonder if the broken 1st gear was from pieces of the 2nd gear?
