shifter slop
- Dean.nabbe
shifter slop
my shifter had some serious slop.. in gear it almost felt like it was in neutral..
i bought a genuine bush kit and change the bushes etc circled in the picture but it's still just as bad.. any idea what else it may be?
[img][IMG]http://www.ausubaru.com.au/picture.php? ... ureid=2103[/img][/IMG]
- Silverbullet
Did you take a look at the fit between the shift fork (item 15) and the selector shaft of the gearbox? one or both components usually wear out where the shaft sits in the tube, makes it real sloppy. Also if you still have the roll pin (item 16) replace it with a bolt and locking nut, tighten the crap out of it. If that still doesn't fix it you need to cut 2 slots in the selector fork tube on each side, so when you tighten the bolt it squeezes the tube down onto the shaft.
- Dean.nabbe
- Silverbullet
- Dean.nabbe
- Dean.nabbe
- Dean.nabbe
eeeeew... attempted to take the fork out to cut it but it's gonna be harder than i thought.. exhaust has to come down first... and by the looks of the fork, someone had a go at it in the past and butchered it.. it looks a bit battered and nasty
1987 Brumby.
still to come:
2"exhaust
winch bar
1987 Brumby.
still to come:
2"exhaust
winch bar
Yeah mine wasn't very clean when I removed it. Exhaust stayed in place.
You will most likely have to drill a new hole in the shaft and this bracket then fit a new bolt with a locking thread nut on it. This gives a really good clamp that ensures it doesn't move.
Your Brumby will feel more like a sports car after this mod
- Dean.nabbe
i'm thinking i may have to weld up all the other holes or replace the pipe section of the fork.. i'll post a pic when i get it out...
gotta take the exhaust down, cant get any spanners/sockets on it with the exhaust bracket in the way...
1987 Brumby.
still to come:
2"exhaust
winch bar
1987 Brumby.
still to come:
2"exhaust
winch bar
- Dean.nabbe
as i previous said.. the shifter fork was a mess... whoever owned it before attempted to fix it... BADLY!!
i wasn't very hopeful, but thought i would still try Bennies suggestion to see if it would fix the slop, before cutting it off and welding a new pipe section to it..
with a new bolt(with less blank) she squeezed down and the slop is gone... very happy... thanks Bennie, Silverbullet and Cliff.
1987 Brumby.
still to come:
2"exhaust
winch bar
1987 Brumby.
still to come:
2"exhaust
winch bar
- Silverbullet
- Dean.nabbe
not my attempt at welding... i just took it off and cleaned it with carby cleaner(was all i had laying around)
i was gonna get a nyloc nut, but decided it was easy enough to do at a later date(ie, when i install the lift kit) wanted to make sure it was gonna work first.
feels much nicer now... i can actually tell the difference between being in neutral and in gear.. lol
1987 Brumby.
still to come:
2"exhaust
winch bar
1987 Brumby.
still to come:
2"exhaust
winch bar
Perfect! Exactly what I need while the car is on the hoist!
Mines got a bolt in it already but the nut on the bottom is gone... lol Time to use a locking nut I think and go from there
EDIT: This worked a treat however I had a spring fall out.. I can see it goes on the selector but can't see where on the gearbox it attaches to??
The only issue I found after doing this mod is that I have to use two hands to force it accross enough to engage reverse. Other than tgat 1-4 is great. Very direct!
