New to Subaru
- d_generate
Welcome, looks like a really nice unit, the only concern is the two black things on the roo bar, probably your tow points but they look pretty lethal and probably highly illegal, they would be over here.
If anyone walking past the front of your car rips a chunk of leg off you could be up for some big medical bills, worse if you hit someone, maybe you could make a rubber block to slip over them.
That's one very clean looking L. Well done. Tinting should help that interior stay nice tooFALCONCONVERTTOSUBARU wrote:
+1 for putting some sort of covers over themd_generate wrote:Welcome, looks like a really nice unit, the only concern is the two black things on the roo bar, probably your tow points but they look pretty lethal and probably highly illegal, they would be over here.
- FALCONCONVERTTOSUBARU
You might have I traverse ippy motorway daily
. i spoke to a copper about them he reckoned because they are tow points they are legal. Yet if I fitted rocket launches used for fishing rods that would be illegal despite the fact my tow points could go through someone like butter it makes no sense but who knows. I do want to get some kind of rubber thing rigged up for them.
- d_generate
Even a couple of tennis balls with a slot cut in them would do the trick, maybe some pink ones
I think if you showed him he might be a little different about it, as the law states that you are not to have anything protruding passed your bumper.FALCONCONVERTTOSUBARU wrote:You might have I traverse ippy motorway daily. i spoke to a copper about them he reckoned because they are tow points they are legal. Yet if I fitted rocket launches used for fishing rods that would be illegal despite the fact my tow points could go through someone like butter it makes no sense but who knows. I do want to get some kind of rubber thing rigged up for them.
Come on.. what's wrong with pink bitsFALCONCONVERTTOSUBARU wrote:I think id rather pass.d_generate wrote:Even a couple of tennis balls with a slot cut in them would do the trick, maybe some pink ones
- d_generate
I like pink bits ............. And STI's had many pink bits, go on, do it!
- d_generate
As for those hooks being placed where they are if you get snatched out of a nasty situation the guy doing it will more than likely end up with your roo bar embedded into the back of his vehicle, attach them to the chassis rails where they should be. Like Paul said, the cop has no idea so just be careful.
Welcome
I've owned two Brumbies and can't complain about the off-road capabilities so far, but if you're after a passenger vehicle then I'd go with a Forester. Have taken a 2004 model off-road a few times, and through the wet and mud and she drove like a dream (and it was an auto!)... but would choose a manual any day. You should be able to pick up a first gen model Foz within your price range (depending on where you look etc).
... BUT in terms of what you're torn between I'd probably go the L-series. They have the potential to be quite grunty and with a lift kit will go almost anywhere.
Hope you find something!
Current vehicles:
2005 Subaru Forester
...no name yet!
Previous vehicles:
1989 Subaru Brumby "Emma"
1989 Subaru Brumby "Brumbylicious"
...no name yet!
Previous vehicles:
wow really
wow where were you? um yeah my little foxie got a broken claw and it bled he needed a bandge. and some pain killer bro accidently stood on his paw and broke it.
My question is that a reasonable fuel consumption for one or should I find radical fuel consumption improvements getting the carby tuned? Car has had fresh oil change but haven't done fuel filter, air filter, plugs, or leads.
I was getting about that with the 3at in my old wagon. It could either improve or get worse with a tune depending on how the engine is running. Even when I did my weber conversion and tuned it myself with a wideband O2 I was still getting double digits per 100km. Wasn't until I swapped to the 4spd man that it improved. The savings in fuel paid for the gearbox in no time.
Maybe pull your plugs and have a look. They can tell you a fair bit about how the engine is running.
Doug
Doug
