1986 Subaru Leone 4wd Factory Turbo
pzs
Post by pzs » Sun May 18, 2014 8:24 pm
Does anyone know what type of diff this is with these markings, eg LSD or open
Post by El_Freddo » Tue May 20, 2014 10:26 pm
pzs wrote:attachment.php?attachmentid=3383&d=1338535890
Probably a good idea to start your own thread rather than use someone elses ;)
My answer is I have no idea...
sublime
Post by sublime » Wed May 21, 2014 5:02 pm
El_Freddo wrote:Probably a good idea to start your own thread rather than use someone elses ;)
+ 1
Not sure on the markings (mine still have the 3.7 LSD stickers!) but the simple test is to jack up the rear of the car and rotate one of the wheels. If the other side moves/spins in the same direction you have an open diff. If the wheels spin in opposite directions you have an LSD.
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
Post by El_Freddo » Sat May 24, 2014 10:58 am
sublime wrote:If the other side moves/spins in the same direction you have an open diff. If the wheels spin in opposite directions you have an LSD.
Other way around! LSD = both in same direction. Open = opposite direction
https://www.youtube.com/watch?v=TI8ewn6HOjg
