Stickers
julian
Post by julian » Wed May 14, 2014 7:50 pm
I've seen plenty of those stickers on the NSW QLD border on 'utility' vehicles with 1 inch of ground clearance.
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
Logos Variations ...
Post by Bantum » Fri May 16, 2014 3:36 am
OK - Finally got 'round to finishing this :
With some variations to suit 900 x 80 mm front windscreen ... there should be at least one among that lot to suit ... :)
Let us know your preferred option ( ie: Banner with Eruostile Bold Ex ) + if you want a specific file format ( Eg: jpg, PDF etc.)
and send in an e-mail ( bantum69 at hotmail.com ) to me, then I can flip it back to you with attachment ... :)
( Note : It will be a largish file - ready for printing + also remove 'at' in address above & replace with @ to e-mail )
Add : That also applies to the other badges ( can add your state emblem ) + Side banner done earlier ...
Then you can get it printed out at your local ... :grin:
Note : I still haven't found the text font that the 'Backyardboys' used though ... :(
Cheers, Bantum ...
Found ...
Post by Bantum » Fri May 16, 2014 1:47 pm
Ok - I think have found it ... It's called : Fat Rhino Regular - Which can also found here : http://www.myfonts.com/fonts/pink-broccoli/fat-rhino/
It's not free though, So Someone has to Buy it ... :(
Add : ie: it's the closet match I found to the original text - have since found out that the original text may have been fudged with W used as M ... :???:
The closest match I can get Free is : ComicsCarToon Regular
Will have to do if your not fussed ... :neutral:
Another font spot to checkout is : fontspace
Type in a sample of your text & browse to see what you like ... :)
( Note : You can forward the font you want to me & I can get it into the banner format if you like )
Ciao, Bantum ...
Johnny T
Post by Johnny T » Fri May 16, 2014 2:02 pm
I like the last banner "Viner Hand ITC" logo, are you able to email me a PSD (Photo shop) copy of that Bantum please :)
Johnny T
88kw of fun waiting to happen
Post by El_Freddo » Fri May 16, 2014 7:21 pm
RSR 555 wrote:It's close but not Boink..
This could be awkward if you came in at the wrong moment on the conversation.
Bantum wrote:Image
I think one of the reasons why we've been able to keep the subaru in our web address is that the owners argued it's AUS-ubaru.com - Subaru did a big "clean up" of un-licenced use of their name to help keep track of where their name is exactly etc. I'm 99% sure this applied to forums as well. I'd rather not advertise it with a two colour effect.
That said, "If we can't get Boink" I like the last one you've posted in that line up ;)
How much does a font cost anyway?
Post by TOONGA » Fri May 16, 2014 7:48 pm
TOONGA wrote:This is as close as I can get without buying the font used in the original sticker.
PS the font is boink
Subyroo wrote:Toonga, you can get that FONT for FREE from here:
http://ttfonts.net/font/4453_BoinkLET.htm
http://www.fontpalace.com/font-download ... LET+Plain/
Subyroo
Yeah I have that one but I wanted the full font set, but Im not paying $30+ for it as thats an oil filter and or spark plugs for one of my cars :)
Bantum wrote:Ok - I think have found it ... It's called : Fat Rhino Regular - Which can also found here : http://www.myfonts.com/fonts/pink-broccoli/fat-rhino/
Ciao, Bantum ...
Using this site http://www.whatfontis.com/ I was able to determine (on the 13th of May) the font is Boink which does look very similar to rhino :)
Comic Relief ...
Post by Bantum » Fri May 16, 2014 8:28 pm
El_Freddo wrote: http://www.AUS-ubaru.com - I'd rather not advertise it with a two colour effect.
Good point - Although its easy enough just to print in one colour - if that's your thing ... :)
El_Freddo wrote: That said, "If we can't get Boink" ...
Although I'm pretty sure 'Fat Rhino' is the one we want, if we can find the one that matches without having to use differing fonts would be good ... ;)
This 'Comic' one will have to do for now :
Note : I've used combination of fonts to get the effect above ... ;)
El_Freddo wrote: How much does a font cost anyway ?
Varies - depends on which site you go to ( Approx. $15 to $30 ) So if you really want it - buy one & send a copy to me ... :p
El_Freddo wrote: I like the last one you've posted in that line up ...
Here ya go :
Note : On closer inspection the edges of text are all fuzzy, not sure if you want that effect or not ... Johnny - I will get a .PSD file of it up shortly ( Need to convert it ) ... ;)
Cheers, Bantum ...
Fat Rhino ...
Post by Bantum » Fri May 16, 2014 8:48 pm
TOONGA wrote: I'm not paying $30+ for it ...
Same here ... :p
TOONGA wrote: I was able to determine the font is Boink - which does look very similar to rhino ...
Fat Rhino seems to cover 90% of text, still tyring to find the one we want ... ;)
Cheers, Bantum ...
Post by TOONGA » Fri May 16, 2014 10:03 pm
I was going off the original sticker which is Boink not fat rhino
Fat Rhino is further away from it than the "comic" one which is nearly the same apart from the bottom of the "O" and the shape of the "C"
Fat rhino
The Original sticker uses a "W" as an "M" in ".com".
Boinked ...
Post by Bantum » Fri May 16, 2014 10:08 pm
Ah, well there ya go - we trying to match a non existent font ... Ha ... :p
Ok - I will have a go at the 'Boink' & see how close it is ... :p
Ended up combining them to get this :
A, C & O are in Boink, the rest of text is in Comic font. + the last letter M is a Rotated W & Reversed ... :twisted:
That's as close as your goanna get ... :p
Cheers, Bantum ...
Post by TOONGA » Fri May 16, 2014 10:33 pm
I used a mixture of BOINK and COMIC to get this as well I used an inverted w to make the "M"
Comic Boink
Post by Bantum » Sat May 17, 2014 9:46 am
Ha - I think we just invented a new font called 'Comic Boink' ... :p
Sounds like a Superhero on steroids ... ;)
Cheers, Bantum ...
Post by 60766244 » Sat May 17, 2014 5:37 pm
I have a big fancy AUSubaru sticker around here somewhere.... When I find it I'll grab some detailed photo and stick it here before I put it on Otter. :)
Post by El_Freddo » Sat May 17, 2014 10:11 pm
That'd be awesome 60766244.
Toonga, that looks pretty bloody close! I'd have one of those if we can't get an original unit knocked up...
Found ...
Post by Bantum » Sun May 18, 2014 2:45 am
I think I might of just found the right font :
Pretty close match without any mods required ( in lowercase ) - What do ya think ?
Can be found Here : Vaca Font ( Oops : fixed link )
Cheers, Bantum ...
More Banners ...
Post by Bantum » Sun May 18, 2014 3:28 am
Ok here are some more ideas thrown into the mixer :
Should make for some interesting meets / spotting opportunities if everyone has there own styled banner ... :)
Cheers, Bantum ...
Post by TOONGA » Sun May 18, 2014 10:30 am
Bantum wrote:I think I might of just found the right font :
Cheers, Bantum ...
Thanks for the font but the site tried to give me a font "EXE" and a tool bar as soon as I visited the page... glad I know what not to select :)
El_Freddo wrote:That'd be awesome 60766244.
Yeah it is close, but I think who ever made the original sticker used commecial fonts and more than one to get the look of the original sticker :)
Wrong link ...
Post by Bantum » Sun May 18, 2014 11:22 am
TOONGA wrote:Thanks for the font but the site tried to give me a font "EXE" and a tool bar as soon as I visited the page ...
Oops sorry - got the link slightly wrong ...:(
Fixed ... :)
Cheers, Bantum ...
More ...
Post by Bantum » Sun May 18, 2014 4:37 pm
Wow, keep digging & eventually you will find what you want ...
Subaru Font : Square 721 Bold Extended BT
Will put it through the 'banner' process & see how it turns out ... :cool:
Cheers, Bantum ...
Squared ...
Post by Bantum » Sun May 18, 2014 9:48 pm
Ok check it out :
Done in the Square 721 Bold Extended BT font ... ;)
Cheers, Bantum ...
