Water bypass pipe
Shorty_T
Water bypass pipe
Post by Shorty_T » Wed Apr 16, 2014 10:54 pm
Hey guys,
After a water bypass pipe for an EA81 as I just discovered mine has two beautiful holes in it.
Anyone have one or know the best place to find one?
Andrew.
Willy Fisterbottom
Post by Willy Fisterbottom » Thu Apr 17, 2014 4:22 am
I made one last week from copper water pipe from Bunnings.
Post by steptoe » Thu Apr 17, 2014 7:26 am
some hydraulic hose specialist joints can make up metal hoses similar to what you want.
does yours have a smaller 7mm ? junction off it ?
Genuine is also still a possibility
Willy Fisterbottom
Post by Willy Fisterbottom » Thu Apr 17, 2014 7:44 am
I screwed in a air fitting into a tee piece for the small vent line.
Shorty_T
Post by Shorty_T » Thu Apr 17, 2014 8:03 am
Thanks for the quick replies guys.
I think the quickest & easiest way out is making a replacement up with copper as suggested.
I'll have a crack tonight & post the results.
Cheers.
Post by steptoe » Thu Apr 17, 2014 8:14 am
make a few extras and stick 'em up for sale !
Subydoug
Post by Subydoug » Thu Apr 17, 2014 8:43 am
Mine was corroded to all hell so I made a new one. I used steel and used the original bracket.
showpost.php?p=224171&postcount=401
Doug
Willy Fisterbottom
Post by Willy Fisterbottom » Thu Apr 17, 2014 8:49 am
Subydoug wrote:Mine was corroded to all hell so I made a new one. I used steel and used the original bracket.
Doug
Did you end up putting in the vent line?
Subydoug
Post by Subydoug » Thu Apr 17, 2014 12:20 pm
No its still plugged up.
Doug
Shorty_T
Post by Shorty_T » Tue Apr 22, 2014 11:55 am
I know it's not really the place for it but here's a bit of an update.
Ran through a few options using what I had lying around & just happened to have some stainless pipe that would work nicely.
Trimmed it up, put some notches in on the lathe, flaired the ends and silver soldered a smaller stainless pipe for the breather. I cut the bracket off the old pipe & riveted it onto the new one with a small bit of sheet.
Went away for the weekend and it performed flawlessly... Until on the way home
I noticed the temp creeping up, turned out another metal pipe nearby has a pinhole leak in it. Managed to fix it with some duct tape & zip ties to get it home :p
It never ends...
Return to “Wanted”
